[petsc-dev] FAS with TS
Peter Brune prbrune at gmail.com
Tue Feb 7 19:19:47 CST 2012
On Tue, Feb 7, 2012 at 6:40 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Suppose I want to solve a finite time step problem using FAS. The time
> step will be defined something like
> static PetscErrorCode SNESTSFormFunction_ARKIMEX(SNES snes,Vec X,Vec F,TS
> ts)
>   TS_ARKIMEX     *ark = (TS_ARKIMEX*)ts->data;
>   PetscErrorCode ierr;
>   PetscFunctionBegin;
>   ierr =
> VecAXPBYPCZ(ark->Ydot,-ark->shift,ark->shift,0,ark->Z,X);CHKERRQ(ierr); /*
> Ydot = shift*(X-Z) */
>   ierr =
> TSComputeIFunction(ts,ark->stage_time,X,ark->Ydot,F,ark->imex);CHKERRQ(ierr);
>   PetscFunctionReturn(0);
> where ark->Z was determined from previous stages and ark->Ydot is a work
> vector. So FAS creates some hierarchy, but it isn't very forthcoming about
> showing the hierarchy to the user. But I need a way to
> 1. Restrict ark->Z to the coarse level and obtain the work vector
> ark->Ydot somewhere that I can reuse it. The user might also have to
> restrict "auxiliary" variables to coarse grids. It's conceivable that they
> would want to do this in a different way from the restriction/prolongation
> for the solution variables. For example, if you were using upwinded R and P
> for a hyperbolic problem, but you needed to restrict coefficients (like
> bathymetry). Or they might want to sample differently out of some file. So
> I think we need an auxiliary transfer callback that is at least called
> every top-level SNESSolve() and optionally also called in every transfer
> (because it could be homogenizing coefficient structure that is a nonlinear
> function of state).
The restriction (injection, etc) might be one step too hard at this point.
We have to define the problem at each level in FAS and grid sequencing so
we might as well make it easy.  Is it possible to have the callback for the
SNES point to things that have to be prolonged or restricted?  This could
be called both before FAS and before grid sequencing to get the
coefficients up to the next level.  We could provide some sort of default
that goes through a number of user-provided vectors on a level given
vectors on another level, and inject them.  A user with user-created
multilevel coefficients could provide their own similar callbacks.
> 2. Put the DM from this SNES into the TS that calls the user's IFunction.
> The easiest way is to have TSPushDM(TS,DM) that just jams it in there,
> caching the old DM (so the user's call to TSGetDM() works correctly), and
> TSPopDM(TS). This is ugly and is scary if the user does something weird
> like TSGetSolution() (returning the state at the beginning of the step, not
> the current value at the stage). This is something that doesn't make
> semantic sense except maybe if they have some weird diagnostics, but
> TSGetIJacobian() might be used for caching, and I'm scared of the semantics
> it would involve to support this sort of caching.
This option seems like it would be scary complex.  I don't like it.
> The alternative is to make different TSs for each level and somehow locate
> the correct TS (maybe cache it in the SNES hierarchy). I think this could
> be quite confusing to restrict all the members to the coarse grid. But
> having a multi-level TS object may eventually be sensible because
> multilevel time integration schemes exist. Spectral deferred correction is
> one example where coarse grids (in space and time) can be used to
> accelerate convergence to a high-order solution. But these somewhat
> naturally expose additional parallelism in time (usually more
> communication, but also more concurrency), so it likely needs a more
> complete solution that includes ways to instantiate entire models on
> sub-communicators (we'll also want an interface of this type for UQ).
I'm not sure this would be harmonious with FAS given the coarse problem is
redefined with a defect from the fine problem (making a FAS cycle on a
actual fine solution do nothing) at each stage.  As I understand it, we'd
need a "real" time derivative rather than a derivative of the defect
problem.  Therefore, we would be stuck solving at each level and using each
level for FAS independently.
However, having a multilevel time integration scheme outside of FAS
accessible to FAS to accelerate solution might be an interesting project;
are there references? Would this look like grid sequencing + FAS with the
grid sequence solutions moved forward in time?
- Peter
> Preferences or suggestions?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120207/79230f13/attachment.html>
