[petsc-dev] [petsc-users] VECMPICUSP with ghosted vector
Dmitry Karpeev karpeev at mcs.anl.gov
Mon Feb 6 15:21:22 CST 2012
On Mon, Feb 6, 2012 at 3:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 6, 2012, at 2:46 PM, Dmitry Karpeev wrote:
> > On Mon, Feb 6, 2012 at 2:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 6, 2012, at 2:28 PM, Dmitry Karpeev wrote:
> > > On Mon, Feb 6, 2012 at 2:06 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > On Feb 6, 2012, at 2:02 PM, Dmitry Karpeev wrote:
> > > > On Mon, Feb 6, 2012 at 1:50 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Feb 6, 2012, at 1:42 PM, Dmitry Karpeev wrote:
> > > > > On Mon, Feb 6, 2012 at 1:30 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > > On Feb 6, 2012, at 1:27 PM, Matthew Knepley wrote:
> > > > > > On Mon, Feb 6, 2012 at 1:23 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > > > On Feb 6, 2012, at 1:14 PM, Matthew Knepley wrote:
> > > > > > > On Mon, Feb 6, 2012 at 1:11 PM, Barry Smith <
> > > > > > > On Feb 6, 2012, at 12:47 PM, Jed Brown wrote:
> > > > > > > > On Mon, Feb 6, 2012 at 21:42, Matthew Knepley <
> knepley at gmail.com> wrote:
> > > > > > > > I don't like this because it would mean calling VecSetUp()
> all over the place. Couldn't the ghosting flag be on the same
> > > > > > > > level as the sizes?
> > > > > > > > Maybe VecSetUp() is wrong because that would imply
> collective. This memory allocation is simple and need not be collective.
> > > > > > > > Ghosting information is an array, so placing it in
> VecSetSizes() would seem unnatural to me. I wouldn't really want
> VecSetGhosts(Vec,PetscInt,const PetscInt*) to be order-dependent with
> respect to VecSetType(), but maybe the VecSetUp() would be too messy.
> > > > > > >   Only some vectors support ghosting, so the usual PETSc way
> (like with KSPGMRESRestart()) is to calling the specific setting routines
> ONLY AFTER the type has been set.  Otherwise all kinds of oddball type
> specific stuff needs to be cached in the object and then pulled out later;
> possible but is that desirable? Who decides what can be set before the type
> and what can be set after? Having a single rule, anything appropriate for a
> subset of the types must be set after the type is set is a nice simple
> model.
> > > > > > >   On the other hand you could argue that ALL vector types
> should support ghosting as a natural thing (with sequential vectors just
> have 0 length ghosts conceptually) then it would be desirable to allow
> setting the ghost information in any ordering.
> > > > > > > I will argue this.
> > > > > >   Ok, then just like VecSetSizes() we stash this information if
> given before the type is set and use it when the type is set.  However if
> it is set after the type is set (and after the sizes are set) then we need
> to destroy the old datastructure and build a new one which means messier
> code.   By instead actually allocating the data structure at VecSetUp() the
> code is cleaner because we never need to take down and rebuild a data
> structure and yet order doesn't matter.  Users WILL need to call VecSetUp()
> before VecSetValues() and possibly a few other things like they do with Mat
> now.
> > > > > > We just disallow setting it after the type, just like sizes. I
> don't see the argument against this.
> > > > >   We allow setting the sizes after the type.
> > > > > Since we are on a related subject: should then all type-specific
> processing of sizes be moved out of MatSetSizes()
> > > > > into MatSetUp?  By this I mean this code:
> > > > >  if (A->ops->setsizes) {
> > > > >     /* Since this will not be set until the type has been set,
> this will NOT be called on the initial
> > > > >        call of MatSetSizes() (which must be called BEFORE
> MatSetType() */
> > > > >     ierr = (*A->ops->setsizes)(A,m,n,M,N);CHKERRQ(ierr);
> > > > >   } else {
> > > > > This eliminates the need to check for the presence of various
> type-specific setup methods  -- they will all be called in MatSetUp after
> the type is guaranteed to have been set.  This would also make MatSetSizes
> not collective.  I imagine that Vec could be organized the same way.  I
> actually would prefer VecSetUp to explicitly delineate the end of the
> "factory" phase.
> > > >   The only Mat one is MatSetSizes_SeqDense() which could be easily
> nuked (someone please check my reasoning) and then the whole concept of
> (*setsizes)() be removed for Mat?
> > > > I think it's useful to allow each Mat type to process size
> information its own way.
> > > > For example "graph-oriented" types like MATADJ, MATIJ may want to
> relax some constraints on the column index spaces (since they are
> inconsequential when MatMult isn't implemented).
> > >   Dmitry,
> > >     I am confused, I though you just argued it could be removed, now
> you want to keep it?  Do you want me to remove the MatSetSizes_*() stuff or
> not?
> > >     My understanding is that you were stating we could remove the
> MatSetSizes_*() and just have that work handled by the MatSetUp_*() or the
> MatXXXSetPreallocation()?
> > > I'm arguing, in part, that MatSetSizes should be handled by a
> type-specific method.  I guess it didn't really occur to me that it could
> be handled by MatSetup_XXX or MatXXXSetPreallocation directly rather than
> by MatSetValues_XXX, but this is as good an arrangement as any.  This is
> more or less the situation now, except that MatSetSizes_XXX could get
> eliminated, so this isn't much of an argument.
> > > What I'm *also* saying is that the logic for checking whether it's
> safe to invoke a type-specific method or not  is scattered around (e.g., in
> MatSetSizes()). Additionally, because of these conditionals in the code
> these methods sometimes are collective (e.g., MatSetSizes() is collective,
> when the type has been set and we are indeed going to process the sizes,
> set up PetscLayouts, etc.), or not (e.g., when the type isn't set and
> MatSetSizes() merely stashes the sizes until better times).  Making methods
> like MatSetSizes() only stash the arguments and then process them all in
> MatSetUp would eliminate the scattered-around conditionals and remove the
> ambiguity about collectivity: things like MatSetSizes aren't collective,
> but MatSetUp is.
> > > I think this is more or less is what is being proposed for Vec as
> well, isn't it?  This also more cleanly reflects the "factory" paradigm,
> which, it seems to me, implicitly underlies the construction of many PETSc
> classes.
> >   The original goal of the (now) convoluted code was to avoid the need
> for VecSetUp() and MatSetUp() and avoid the need (when at all possible) for
> stashing type specific information for later use; the code became more
> convoluted in an attempt to keep the no setup paradigm.
> > Okay, so it seems like we are all for the stashing and an explicit call
> VecSetUp or MatSetUp to process the stashed data later.  I'm definitely for
> it.
>    Wow, hold on. How much stuff stashed? Anything? Or just sizes and ghost
> points. Stash the preallocation information and don't preallocate until the
> setup? If the user sets five different preallocation informations do we
> stash them all and us the right one at setup?
>    Currently MatXXXSetPreallocation() is ignored unless the type as
> already been set to XXX and then it immediately builds the data structure
> at that point, it does not stash it until MatSetUp()
Right. Some data is type-independent (e.g., sizes), but can be processed in
a type-specific way, while other data is type-specific (e.g.,
preallocation).  To stash the type-specific stuff the type must be set
first.  Not only that, the type-specific data structure may need to be
constructed (and blown away, if the user chooses to reset the type before
XXXSetUp?).   Even sizes are type-specific to some extent (Seq vs MPI).
Dmitry.
>   Barry
> > Dmitry.
> >   Barry
> > > Dmitry.
> > >    Barry
> > > > Dmitry.
> > > >   Barry
> > > > > Dmitry.
> > > > > >    Matt
> > > > > >   Barry
> > > > > > >   Sadly we now pretty much require MatSetUp() or a
> MatXXXSetPreallocation() to be called so why not always have VecSetUp()
> always called?
> > > > > > > Because I don't think we need it and it is snother layer of
> complication for the user and us. I think
> > > > > > > we could make it work where it was called automatically when
> necessary, but that adds another
> > > > > > > headache for maintenance and extension.
> > > > > > >     Matt
> > > > > > >   We have not converged yet,
> > > > > > >    Barry
> > > > > > > What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any results to which
> their experiments lead.
> > > > > > > -- Norbert Wiener
> > > > > > What most experimenters take for granted before they begin their
> experiments lead.
> > > > > > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120206/0244d1e3/attachment.html>
