[petsc-dev] MatMatMult gives different results
Alexander Grayver agrayver at gfz-potsdam.de
Mon Feb 6 05:55:47 CST 2012
Dear PETSc team,
I try to use:
call
MatMatMult(A,B,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,C,ierr);CHKERRQ(ierr)
Where both A and B are rectangular, but A is sparse and B is dense. Both
are double complex and distributed.
The product PETSc gives me contains some errors in some part of the matrix.
I output A, B and C then computed product in matlab.
Attached you see figure plotted as:
imagesc(log10(abs(C-Cm)))
Where Cm -- product computed in matlab.
The pattern and amplitude vary depending on the number of cores I use.
This picture is obtained for 48 cores (I've tried 12, 64 cores as well).
Where should I look for possible explanation?
Alexander
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120206/f2089dfd/attachment.png>
