[petsc-dev] Error with DMCompositeGetISLocalToGlobalMappings
domenico.borzacchiello at univ-st-etienne.fr domenico.borzacchiello at univ-st-etienne.fr
Fri Feb 3 09:32:40 CST 2012
I'm getting a segmentation violation error when I use
DMCompositeGetISLocalToGlobalMappings on a DMComposite defined redundantly
on subsets of the PETSC_COMM_WORLD. I could reproduce the error in the
small code you can find here attached. It creates a PetsSubcomm from
PETSC_COMM_WORLD, then it defines a DMDA on the Subcomm->comm and finally
it packs it into a DMComposite.
I get this error whenever I call DMCompositeGetISLocalToGlobalMapping on a
DMComposite defined in such a way.
I would be glad if you could give it a look.
Thank you
Domenico
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120203/c3618a83/attachment.bin>
