[petsc-dev] Documentation comment support
Sun Dec 23 21:16:00 CST 2012
On Sun, Dec 23, 2012 at 9:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I do not want to give up on namedest yet. There are some suggestions here:
> http://sbml.org/Forums/index.php?t=tree&goto=7873&rid=0
> 1) The guys says to try the Acrobat plugin for Firefox
... confirming that it's totally non-portable.
PDF isn't a great format for the web for many reasons including that it
always loads the entire 1.5MB document and that "back" buttons are much
less reliable when following links in a PDE. Since #page is the most nearly
portable solution, I don't mind using that end eventually finding a way to
produce good-looking HTML output.
> 2) He says you need the hyperref option "destlabel=true".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121223/acdda49b/attachment.html>
