[petsc-dev] MIC available for testing
Karl Rupp rupp at mcs.anl.gov
Fri Dec 14 15:49:06 CST 2012
Hi guys,
today I got a gentle introduction into our testing machine equipped with
two Intel MICs. They are still beta, yet I could run some simple kernels
in native mode. As an example, without any modification of existing
OpenMP code for vector addition in double precision of 3e6 elements, I
got the following timings:
-- Native mode, i.e. all code executed on MIC --
Single core time: 0.642 sec
All-core time:    0.011 sec
For offloaded execution (CPU <-> MIC, just like with GPUs), additional
pragmas are required, I haven't tried that yet.
For comparison, the same code on the CPU (Sandy Bridge, 8x2 cores, 2.6
GHz) takes 0.060 sec without OpenMP and 0.030 sec with OpenMP. Thus, the
conclusion is that one *really* needs to get all cores on the MIC busy
in order to get the full memory bandwidth. Thus, a plain 'just recompile
for MIC and you get good performance' won't work for most applications
in practice, simply because the serial performance is so limited.
@Shri: It would be interesting to give pthreads a try, particularly how
it compares with OpenMP. I'll be out of the lab until the beginning of
January, but I can help you with getting an account and getting started.
Btw: I just got a call regarding Altera hardware, we might have chances
to get our fingers on their OpenCL-enabled hardware.
Best regards,
Karli
