[petsc-dev] example incorrectly labeled please fix for nightly tests
Thu Dec 13 18:41:29 CST 2012
https://bitbucket.org/petsc/petsc-dev/commits/160bd758915b935d438182c2f407757baf57ec38
On Sun, Dec 9, 2012 at 8:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Since this example requires exodusii this example should not be listed
> in the makefile under TESTEXAMPLES_C or friends, it should be listed under
> TESTEXAMPLES_EXODUSII and then it will only get triggered when exodusii is
> installed. Please fix whoever listed this wrong.
>    Thanks
>     Barry
> /Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpicc -o ex11.o -c -fPIC
> -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3
> -fno-inline -O0 -fopenmp -I/Users/barrysmith/Src/petsc-dev/include
> -I/Users/barrysmith/Src/petsc-dev/arch-gnu/include
> -I/usr/local/include/libAfterImage/ -I/opt/X11/include
> -I/Users/barrysmith/Src/ams-dev/include -I/opt/local/include
> -D__INSDIR__=src/ts/examples/tutorials/ ex11.c
> ex11.c:11:2: error: #error This example requires ExodusII support.
> Reconfigure using --download-exodusii
> ex11.c: In function ‘main’:
> ex11.c:2191: warning: implicit declaration of function ‘ex_open’
> ex11.c:2191: error: ‘EX_READ’ undeclared (first use in this function)
> ex11.c:2191: error: (Each undeclared identifier is reported only once
> ex11.c:2191: error: for each function it appears in.)
> ex11.c:2195: warning: implicit declaration of function ‘ex_close’
> make[7]: [ex11.o] Error 1 (ignored)
> /Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpicc -fopenmp
> -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress
> -Wl,-commons,use_dylibs -Wl,-search_paths_first
> -Wl,-commons,use_dylibs -Wl,-search_paths_first  -fPIC -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline
> -O0 -fopenmp  -o ex11 ex11.o
>  -L/Users/barrysmith/Src/petsc-dev/arch-gnu/lib
> -L/Users/barrysmith/Src/petsc-dev/arch-gnu/lib  -lpetsc -lcmumps -ldmumps
> -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lblacs -lHYPRE
> -L/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64
> -L/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64
> -lmpichcxx -lstdc++ -lml -lmpichcxx -lstdc++ -lsuperlu_4.3
> -lsuperlu_dist_3.2 -llapack -lblas
> -L/usr/local/include/libAfterImage/../../lib -lAfterImage -ltriangle
> -L/opt/X11/lib -lX11 -L/Users/barrysmith/Src/ams-dev/lib -lamspub
> -lparmetis -lmetis -lfftw3_mpi -lfftw3 -lptesmumps -lptscotch -lptscotcherr
> -lpthread -lyaml -lmpichf90 -lgfortran
> -L/usr/local/lib/gcc/x86_64-apple-darwin10.7.0/4.6.0 -L/usr/local/lib
> -lgfortran -lgcc_ext.10.5 -lquadmath -lm -lm -lmpichcxx -lstdc++ -lm -lz
> -lz -ldl -lpmpich -lmpich -lopa -lmpl -lSystem -ldl
> i686-apple-darwin11-llvm-gcc-4.2: ex11.o: No such file or directory
> make[7]: [ex11] Error 1 (ignored)
> /bin/rm -f ex11.o
> 1,6d0
> < timestep 0: time 0, solution norm 1.9391
> < timestep 1: time 0.01, solution norm 1.16241
> < timestep 2: time 0.02, solution norm 0.828933
> < timestep 3: time 0.03, solution norm 0.648333
> < timestep 4: time 0.04, solution norm 0.528016
> < timestep 5: time 0.05, solution norm 0.437213
> /Users/barrysmith/Src/petsc-dev/src/ts/examples/tutorials
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121213/53e8554e/attachment.html>
