[petsc-dev] making make cmake less verbose
Thu Dec 13 15:39:22 CST 2012
  Satish,
   No need to do this change. I would like the current make cmake to continue to behave exactly as it does now.
   Barry
On Dec 13, 2012, at 3:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 13 Dec 2012, Barry Smith wrote:
>> On Dec 13, 2012, at 3:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> It is displaying all the debugging information. You'll only get the useful information if you run this:
>>> make -j5 -C arch-gnu
>>   Yes, your suggestion is not verbose because it doesn't do anything
>> Barrys-MacBook-Pro:tutorials barrysmith$ make -j5 -C arch-gnu
>> make: *** arch-gnu: No such file or directory.  Stop.
>> Barrys-MacBook-Pro:tutorials barrysmith$ pwd
>> /Users/barrysmith/Src/petsc-dev/src/snes/examples/tutorials
>>   I don't want a "clean" top-level only command, like make cmake I want to run this command from whatever directory I am in and have it work correctly.
>>    I guess I'll just add the rule   ccmake: pushd ${PETSC_DIR} ; make -j5 -C ${PETSC_ARCH}; popd in the conf/rules makefile, would that be reasonable?
> Looks like the primary issue here is the extra option to make
> 'VERBOSE=1' in the taret 'cmake'. And this is there primarily for the
> top level make target to gather details into make.log
> How about the following?
> Satish
> asterix:/home/balay/spetsc>hg diff
> diff --git a/conf/rules b/conf/rules
> --- a/conf/rules
> +++ b/conf/rules
> @@ -85,7 +85,7 @@
> cmake: chk_makej
>        @echo "Building PETSc using CMake with ${MAKE_NP} build threads"
>        @echo "=========================================="
> -       @cd ${PETSC_DIR}/${PETSC_ARCH} && ${OMAKE} -j ${MAKE_NP} VERBOSE=1
> +       @cd ${PETSC_DIR}/${PETSC_ARCH} && ${OMAKE} -j ${MAKE_NP} VERBOSE=${VERBOSE}
>        @if [ "${BUILDSHAREDLIB}" = "yes" -a "${DSYMUTIL}" != "true" ]; then \
>         echo "Running ${DSYMUTIL} on ${SHLIBS}";\
>         for LIBNAME in ${SHLIBS}; do ${DSYMUTIL} ${INSTALL_LIB_DIR}/$$LIBNAME.${SL_LINKER_SUFFIX}; done; fi
> diff --git a/makefile b/makefile
> --- a/makefile
> +++ b/makefile
> @@ -24,7 +24,7 @@
>   @${OMAKE}  PETSC_ARCH=${PETSC_ARCH}  PETSC_DIR=${PETSC_DIR} chkpetsc_dir petscnagupgrade | tee ${PETSC_ARCH}/conf/make.log
>   @ln -sf ${PETSC_ARCH}/conf/make.log make.log
>   @if [ "${PETSC_BUILD_USING_CMAKE}" != "" ]; then \
> -     ${OMAKE} PETSC_ARCH=${PETSC_ARCH} PETSC_DIR=${PETSC_DIR} all-cmake 2>&1 | tee -a ${PETSC_ARCH}/conf/make.log \
> +        ${OMAKE} PETSC_ARCH=${PETSC_ARCH} PETSC_DIR=${PETSC_DIR} all-cmake VERBOSE=1 2>&1 | tee -a ${PETSC_ARCH}/conf/make.log \
>                  | egrep -v '( --check-build-system |cmake -E | -o CMakeFiles/petsc[[:lower:]]*.dir/| -o lib/libpetsc|CMakeFiles/petsc[[:lower:]]*\.dir/(build|depend|requires)|-f CMakeFiles/Makefile2|Dependee .* is newer than depender |provides\.build. is up to date)'; \
>                   else \
>                      ${OMAKE} PETSC_ARCH=${PETSC_ARCH} PETSC_DIR=${PETSC_DIR} all-legacy 2>&1 | tee -a ${PETSC_ARCH}/conf/make.log \
