[petsc-dev] making make cmake less verbose
Thu Dec 13 14:59:59 CST 2012
  Jed,
   When I have edited PETSc source and want to update the libraries I use make cmake. It produces so much clutter that it is hard to see the relevant bits. Could there be an alternative make cmakeclear that only displays the files that have changed (and hence will be compiled), the compile output for the compiled files and any error messages from making the library? I must spend 30% of each day wading through this stuff looking for the good stuff.
That is, don't tell me about the fortran modules it is not rebuilding, and don't tell me the name of every damn file that is put in the library, as well as all the cds it did.
   Thanks
   Barry
make PETSC_DIR=/Users/barrysmith/Src/petsc-dev PETSC_ARCH=arch-gnu cmake
Building PETSc using CMake with 5 build threads
 /Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -H/Users/barrysmith/Src/petsc-dev -B/Users/barrysmith/Src/petsc-dev/arch-gnu --check-build-system CMakeFiles/Makefile.cmake 0
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_progress_start /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles/progress.marks
/usr/bin/make -f CMakeFiles/Makefile2 all
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/depend
cd /Users/barrysmith/Src/petsc-dev/arch-gnu && /Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_depends "Unix Makefiles" /Users/barrysmith/Src/petsc-dev /Users/barrysmith/Src/petsc-dev /Users/barrysmith/Src/petsc-dev/arch-gnu /Users/barrysmith/Src/petsc-dev/arch-gnu /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles/petsc.dir/DependInfo.cmake --color=
Dependee "/Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c" is newer than depender "CMakeFiles/petsc.dir/src/snes/interface/snes.c.o".
Clearing dependencies in "/Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles/petsc.dir/depend.make".
Scanning dependencies of target petsc
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/requires
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/vec/f90-mod/petscvecmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/vec/f90-mod/petscvecmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/dm/f90-mod/petscdmmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/dm/f90-mod/petscdmmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/ksp/f90-mod/petsckspmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/ksp/f90-mod/petsckspmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/src/snes/f90-mod/petscsnesmod.F.o.provides.build
make[4]: `CMakeFiles/petsc.dir/src/snes/f90-mod/petscsnesmod.F.o.provides.build' is up to date.
/usr/bin/make -f CMakeFiles/petsc.dir/build.make CMakeFiles/petsc.dir/build
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_progress_report /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles
[  0%] Building C object CMakeFiles/petsc.dir/src/snes/interface/snes.c.o
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpicc  -D__INSDIR__="" -Dpetsc_EXPORTS -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -fopenmp -fPIC -I/Users/barrysmith/Src/petsc-dev/include -I/Users/barrysmith/Src/petsc-dev/arch-gnu/include -I/usr/local/include/libAfterImage -I/opt/X11/include -I/Users/barrysmith/Src/ams-dev/include -I/opt/local/include    -o CMakeFiles/petsc.dir/src/snes/interface/snes.c.o   -c /Users/barrysmith/Src/petsc-dev/src/snes/interface/snes.c
Linking Fortran shared library lib/libpetsc.dylib
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_link_script CMakeFiles/petsc.dir/link.txt --verbose=1
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpif90   -fPIC  -Wall -Wno-unused-variable -Wno-unused-dummy-argument -g -fopenmp -dynamiclib -Wl,-headerpad_max_install_names   -o lib/libpetsc.dylib -install_name /Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libpetsc.dylib CMakeFiles/petsc.dir/src/sys/utils/arch.c.o CMakeFiles/petsc.dir/src/sys/utils/fhost.c.o CMakeFiles/petsc.dir/src/sys/utils/fuser.c.o CMakeFiles/petsc.dir/src/sys/utils/memc.c.o CMakeFiles/petsc.dir/src/sys/utils/mpiu.c.o CMakeFiles/petsc.dir/src/sys/utils/psleep.c.o CMakeFiles/petsc.dir/src/sys/utils/sortd.c.o CMakeFiles/petsc.dir/src/sys/utils/sorti.c.o CMakeFiles/petsc.dir/src/sys/utils/str.c.o CMakeFiles/petsc.dir/src/sys/utils/sortip.c.o CMakeFiles/petsc.dir/src/sys/utils/pbarrier.c.o CMakeFiles/petsc.dir/src/sys/utils/pdisplay.c.o CMakeFiles/petsc.dir/src/sys/utils/ctable.c.o CMakeFiles/petsc.dir/src/sys/utils/psplit.c.o CMakeFiles/petsc.dir/src/sys/utils/select.c.o CMakeFiles/petsc.dir/src/sys/utils/mpimesg.c.o CMakeFiles/petsc.dir/src/sys/utils/sseenabled.c.o CMakeFiles/petsc.dir/src/sys/utils/mpitr.c.o CMakeFiles/petsc.dir/src/sys/utils/mpilong.c.o CMakeFiles/petsc.dir/src/sys/utils/mathinf.c.o CMakeFiles/petsc.dir/src/sys/dll/dlimpl.c.o CMakeFiles/petsc.dir/src/sys/dll/dl.c.o CMakeFiles/petsc.dir/src/sys/dll/reg.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/tikz/tikz.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/draw.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dline.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dlinew.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dlinegw.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dtext.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dtextv.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dtexts.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dtextgs.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dpoint.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dpoints.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dviewp.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dcoor.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dpause.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dgpause.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dgcoor.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dbuff.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dsetpause.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dflush.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dsflush.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dclear.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dsclear.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/drect.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dtri.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dmouse.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/drawreg.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/drawregall.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/dellipse.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/axis.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/lg.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/dscatter.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/hists.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/zoom.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/hue.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/lgc.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/axisc.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/binary/binv.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/draw/drawv.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/vu/petscvu.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/vtk/vtkv.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ascii/filev.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ascii/vcreatea.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/string/stringv.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/view.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/flush.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/viewregall.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/viewreg.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/viewa.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/dlregispetsc.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/viewers.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/dupl.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/random.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/randreg.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/dlregisrand.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/randomc.c.o CMakeFiles/petsc.dir/src/sys/classes/bag/bag.c.o CMakeFiles/petsc.dir/src/sys/classes/sf/dlregissf.c.o CMakeFiles/petsc.dir/src/sys/classes/sf/sf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ffpath.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftest.c.o CMakeFiles/petsc.dir/src/sys/fileio/ghome.c.o CMakeFiles/petsc.dir/src/sys/fileio/mpiuopen.c.o CMakeFiles/petsc.dir/src/sys/fileio/rpath.c.o CMakeFiles/petsc.dir/src/sys/fileio/fpath.c.o CMakeFiles/petsc.dir/src/sys/fileio/fwd.c.o CMakeFiles/petsc.dir/src/sys/fileio/grpath.c.o CMakeFiles/petsc.dir/src/sys/fileio/mprint.c.o CMakeFiles/petsc.dir/src/sys/fileio/sysio.c.o CMakeFiles/petsc.dir/src/sys/fileio/fretrieve.c.o CMakeFiles/petsc.dir/src/sys/fileio/smatlab.c.o CMakeFiles/petsc.dir/src/sys/memory/mal.c.o CMakeFiles/petsc.dir/src/sys/memory/mem.c.o CMakeFiles/petsc.dir/src/sys/memory/mtr.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/impls/nothread/nothread.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/interface/dlregisthreadcomm.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/interface/threadcomm.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/interface/threadcommregi.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/interface/threadcommred.c.o CMakeFiles/petsc.dir/src/sys/shell/interface/sysshell.c.o CMakeFiles/petsc.dir/src/sys/python/pythonsys.c.o CMakeFiles/petsc.dir/src/sys/error/adebug.c.o CMakeFiles/petsc.dir/src/sys/error/err.c.o CMakeFiles/petsc.dir/src/sys/error/errtrace.c.o CMakeFiles/petsc.dir/src/sys/error/errabort.c.o CMakeFiles/petsc.dir/src/sys/error/errstop.c.o CMakeFiles/petsc.dir/src/sys/error/fp.c.o CMakeFiles/petsc.dir/src/sys/error/signal.c.o CMakeFiles/petsc.dir/src/sys/error/pstack.c.o CMakeFiles/petsc.dir/src/sys/objects/version.c.o CMakeFiles/petsc.dir/src/sys/objects/gcomm.c.o CMakeFiles/petsc.dir/src/sys/objects/gtype.c.o CMakeFiles/petsc.dir/src/sys/objects/olist.c.o CMakeFiles/petsc.dir/src/sys/objects/pname.c.o CMakeFiles/petsc.dir/src/sys/objects/tagm.c.o CMakeFiles/petsc.dir/src/sys/objects/destroy.c.o CMakeFiles/petsc.dir/src/sys/objects/gcookie.c.o CMakeFiles/petsc.dir/src/sys/objects/inherit.c.o CMakeFiles/petsc.dir/src/sys/objects/options.c.o CMakeFiles/petsc.dir/src/sys/objects/pgname.c.o CMakeFiles/petsc.dir/src/sys/objects/prefix.c.o CMakeFiles/petsc.dir/src/sys/objects/init.c.o CMakeFiles/petsc.dir/src/sys/objects/pinit.c.o CMakeFiles/petsc.dir/src/sys/objects/ptype.c.o CMakeFiles/petsc.dir/src/sys/objects/state.c.o CMakeFiles/petsc.dir/src/sys/objects/aoptions.c.o CMakeFiles/petsc.dir/src/sys/objects/mpinit.c.o CMakeFiles/petsc.dir/src/sys/objects/subcomm.c.o CMakeFiles/petsc.dir/src/sys/totalview/tv_data_display.c.o CMakeFiles/petsc.dir/src/sys/info/verboseinfo.c.o CMakeFiles/petsc.dir/src/sys/logging/plog.c.o CMakeFiles/petsc.dir/src/sys/logging/plogmpe.c.o CMakeFiles/petsc.dir/src/sys/time/cputime.c.o CMakeFiles/petsc.dir/src/sys/time/fdate.c.o CMakeFiles/petsc.dir/src/sys/time/ptime.c.o CMakeFiles/petsc.dir/src/sys/classes/random/impls/rand48/rand48.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/xinit.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/wmap.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/xcolor.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/xops.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/text.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/tone.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/drawopenx.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/impls/x/ftn-custom/zdrawopenxf.c.o CMakeFiles/petsc.dir/src/sys/logging/utils/classLog.c.o CMakeFiles/petsc.dir/src/sys/logging/utils/stageLog.c.o CMakeFiles/petsc.dir/src/sys/logging/utils/eventLog.c.o CMakeFiles/petsc.dir/src/sys/logging/utils/stack.c.o CMakeFiles/petsc.dir/src/sys/classes/bag/f2003-src/fsrc/bagenum.F.o CMakeFiles/petsc.dir/src/sys/objects/f2003-src/fsrc/optionenum.F.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/socket/send.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/socket/ftn-custom/zsendf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/binary/f90-custom/zbinvf90.c.o CMakeFiles/petsc.dir/src/sys/classes/bag/f90-custom/zbagf90.c.o CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o CMakeFiles/petsc.dir/src/sys/f90-src/f90_cwrap.c.o CMakeFiles/petsc.dir/src/sys/f90-src/fsrc/f90_fwrap.F.o CMakeFiles/petsc.dir/src/sys/yaml/yamlimpls.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/impls/openmp/tcopenmp.c.o CMakeFiles/petsc.dir/src/sys/classes/random/impls/rand/rand.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/memcf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/mpiuf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/psleepf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/psplitf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/sortdf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/sortif.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-auto/sortipf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-custom/zarchf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-custom/zstrf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-custom/zpbarrierf.c.o CMakeFiles/petsc.dir/src/sys/utils/ftn-custom/zfhostf.c.o CMakeFiles/petsc.dir/src/sys/dll/ftn-auto/regf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dbufff.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dclearf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dcoorf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dellipsef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dflushf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dgcoorf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dgpausef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dlinef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dlinegwf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dlinewf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dmousef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dpausef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dpointf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dpointsf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/drawf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/drawregf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/drectf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dsclearf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dsetpausef.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dsflushf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dtextgsf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dtextsf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dtrif.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-auto/dviewpf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-custom/zdrawf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-custom/zdrawregf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-custom/zdtextf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-custom/zdtextvf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/interface/ftn-custom/zdtrif.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/axiscf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/axisf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/dscatterf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/histsf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/lgcf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-auto/lgf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zaxisf.c.o CMakeFiles/petsc.dir/src/sys/classes/draw/utils/ftn-custom/zzoomf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/binary/ftn-auto/binvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/binary/ftn-custom/zbinvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/draw/ftn-auto/drawvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/draw/ftn-custom/zdrawvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/vtk/ftn-custom/zvtkvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ascii/ftn-auto/filevf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ascii/ftn-custom/zfilevf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ascii/ftn-custom/zvcreatef.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/string/ftn-custom/zstringvf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/ftn-auto/duplf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/ftn-auto/flushf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/ftn-auto/viewf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/ftn-auto/viewregf.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/interface/ftn-custom/zviewaf.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomcf.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-auto/randomf.c.o CMakeFiles/petsc.dir/src/sys/classes/random/interface/ftn-custom/zrandomf.c.o CMakeFiles/petsc.dir/src/sys/classes/bag/ftn-auto/bagf.c.o CMakeFiles/petsc.dir/src/sys/classes/bag/ftn-custom/zbagf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-auto/mpiuopenf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-auto/mprintf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-auto/sysiof.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-custom/zghomef.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-custom/zmpiuopenf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-custom/zmprintf.c.o CMakeFiles/petsc.dir/src/sys/fileio/ftn-custom/zsysiof.c.o CMakeFiles/petsc.dir/src/sys/memory/ftn-auto/memf.c.o CMakeFiles/petsc.dir/src/sys/memory/ftn-custom/zmtrf.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/interface/ftn-auto/threadcommf.c.o CMakeFiles/petsc.dir/src/sys/ftn-custom/zsys.c.o CMakeFiles/petsc.dir/src/sys/ftn-custom/zutils.c.o CMakeFiles/petsc.dir/src/sys/python/ftn-custom/zpythonf.c.o CMakeFiles/petsc.dir/src/sys/error/ftn-auto/adebugf.c.o CMakeFiles/petsc.dir/src/sys/error/ftn-auto/errf.c.o CMakeFiles/petsc.dir/src/sys/error/ftn-auto/fpf.c.o CMakeFiles/petsc.dir/src/sys/error/ftn-auto/signalf.c.o CMakeFiles/petsc.dir/src/sys/error/ftn-custom/zerrf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/destroyf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/gcommf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/inheritf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/optionsf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/pinitf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/ptypef.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-auto/tagmf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zgcommf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zoptionsf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zpgnamef.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zpnamef.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zprefixf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zdestroyf.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zstart.c.o CMakeFiles/petsc.dir/src/sys/objects/ftn-custom/zstartf.c.o CMakeFiles/petsc.dir/src/sys/info/ftn-auto/verboseinfof.c.o CMakeFiles/petsc.dir/src/sys/info/ftn-custom/zverboseinfof.c.o CMakeFiles/petsc.dir/src/sys/logging/ftn-auto/plogf.c.o CMakeFiles/petsc.dir/src/sys/logging/ftn-custom/zplogf.c.o CMakeFiles/petsc.dir/src/sys/fsrc/somefort.F.o CMakeFiles/petsc.dir/src/sys/time/ftn-auto/cputimef.c.o CMakeFiles/petsc.dir/src/sys/time/ftn-auto/ptimef.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ams/ams.c.o CMakeFiles/petsc.dir/src/sys/classes/viewer/impls/ams/amsopen.c.o CMakeFiles/petsc.dir/src/sys/ams/pams.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tcpthread.c.o CMakeFiles/petsc.dir/src/sys/threadcomm/impls/pthread/tclockfree.c.o CMakeFiles/petsc.dir/src/vec/ftn-custom/zis.c.o CMakeFiles/petsc.dir/src/vec/pf/interface/ftn-auto/pff.c.o CMakeFiles/petsc.dir/src/vec/is/impls/stride/ftn-auto/stridef.c.o CMakeFiles/petsc.dir/src/vec/is/impls/block/ftn-auto/blockf.c.o CMakeFiles/petsc.dir/src/vec/is/impls/block/ftn-custom/zblockf.c.o CMakeFiles/petsc.dir/src/vec/is/impls/general/ftn-auto/generalf.c.o CMakeFiles/petsc.dir/src/vec/is/interface/ftn-auto/indexf.c.o CMakeFiles/petsc.dir/src/vec/is/interface/ftn-auto/isregf.c.o CMakeFiles/petsc.dir/src/vec/is/interface/ftn-custom/zindexf.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/iscoloringf.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/iscompf.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/isdifff.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-auto/isltogf.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-custom/ziscoloringf.c.o CMakeFiles/petsc.dir/src/vec/is/utils/ftn-custom/zisltogf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/shared/ftn-auto/shvecf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/nest/ftn-auto/vecnestf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/ftn-auto/vsectionf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/ftn-auto/vseqcrf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/ftn-custom/zbvec2f.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/ftn-custom/zvsectionf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/ftn-auto/commonmpvecf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/ftn-auto/pbvecf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/ftn-auto/vmpicrf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/ftn-custom/zpbvecf.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/ftn-auto/rvectorf.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/ftn-auto/veccreatef.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/ftn-auto/vectorf.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/ftn-custom/zvecregf.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/ftn-custom/zvectorf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/cmeshf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/combf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/veciof.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/vecmpitoseqf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/vinvf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/vpscatf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-auto/vscatf.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/ftn-custom/zvscatf.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/hypre/vhyp.c.o CMakeFiles/petsc.dir/src/vec/pf/impls/constant/const.c.o CMakeFiles/petsc.dir/src/vec/pf/impls/string/cstring.c.o CMakeFiles/petsc.dir/src/vec/pf/interface/pf.c.o CMakeFiles/petsc.dir/src/vec/pf/interface/pfall.c.o CMakeFiles/petsc.dir/src/vec/is/impls/stride/stride.c.o CMakeFiles/petsc.dir/src/vec/is/impls/block/block.c.o CMakeFiles/petsc.dir/src/vec/is/impls/general/general.c.o CMakeFiles/petsc.dir/src/vec/is/interface/index.c.o CMakeFiles/petsc.dir/src/vec/is/interface/isregall.c.o CMakeFiles/petsc.dir/src/vec/is/interface/isreg.c.o CMakeFiles/petsc.dir/src/vec/is/utils/iscomp.c.o CMakeFiles/petsc.dir/src/vec/is/utils/iscoloring.c.o CMakeFiles/petsc.dir/src/vec/is/utils/isltog.c.o CMakeFiles/petsc.dir/src/vec/is/utils/isdiff.c.o CMakeFiles/petsc.dir/src/vec/is/utils/isblock.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/shared/shvec.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/nest/vecnest.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/bvec2.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/bvec1.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/dvec2.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/vseqcr.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/bvec3.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/vsection.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pbvec.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pdvec.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pvec2.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/pmap.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/vmpicr.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/mpi/commonmpvec.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/vector.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/veccreate.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/vecreg.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/vecregall.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/dlregisvec.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/rvector.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vinv.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vscat.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vpscat.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/cmesh.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vecio.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/comb.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vecstash.c.o CMakeFiles/petsc.dir/src/vec/vec/utils/vecmpitoseq.c.o CMakeFiles/petsc.dir/src/vec/f90-mod/petscvecmod.F.o CMakeFiles/petsc.dir/src/vec/is/impls/f90-custom/zblockf90.c.o CMakeFiles/petsc.dir/src/vec/is/interface/f90-custom/zindexf90.c.o CMakeFiles/petsc.dir/src/vec/is/utils/f90-custom/ziscoloringf90.c.o CMakeFiles/petsc.dir/src/vec/vec/impls/seq/f90-custom/zvsectionf90.c.o CMakeFiles/petsc.dir/src/vec/vec/interface/f90-custom/zvectorf90.c.o CMakeFiles/petsc.dir/src/mat/color/degr.c.o CMakeFiles/petsc.dir/src/mat/color/setr.c.o CMakeFiles/petsc.dir/src/mat/color/dsm.c.o CMakeFiles/petsc.dir/src/mat/color/ido.c.o CMakeFiles/petsc.dir/src/mat/color/numsrt.c.o CMakeFiles/petsc.dir/src/mat/color/seq.c.o CMakeFiles/petsc.dir/src/mat/color/slo.c.o CMakeFiles/petsc.dir/src/mat/color/color.c.o CMakeFiles/petsc.dir/src/mat/color/scolor.c.o CMakeFiles/petsc.dir/src/mat/partition/partition.c.o CMakeFiles/petsc.dir/src/mat/partition/spartition.c.o CMakeFiles/petsc.dir/src/mat/matfd/fdmatrix.c.o CMakeFiles/petsc.dir/src/mat/coarsen/coarsen.c.o CMakeFiles/petsc.dir/src/mat/coarsen/scoarsen.c.o CMakeFiles/petsc.dir/src/mat/coarsen/impls/hem/hem.c.o CMakeFiles/petsc.dir/src/mat/coarsen/impls/mis/mis.c.o CMakeFiles/petsc.dir/src/mat/interface/matrix.c.o CMakeFiles/petsc.dir/src/mat/interface/mhas.c.o CMakeFiles/petsc.dir/src/mat/interface/matreg.c.o CMakeFiles/petsc.dir/src/mat/interface/matregis.c.o CMakeFiles/petsc.dir/src/mat/interface/matnull.c.o CMakeFiles/petsc.dir/src/mat/interface/dlregismat.c.o CMakeFiles/petsc.dir/src/mat/impls/submat/submat.c.o CMakeFiles/petsc.dir/src/mat/impls/is/matis.c.o CMakeFiles/petsc.dir/src/mat/impls/fft/fft.c.o CMakeFiles/petsc.dir/src/mat/impls/ij/stashij.c.o CMakeFiles/petsc.dir/src/mat/impls/ij/matij.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baij.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baij2.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact2.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgedi.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa3.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa4.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa5.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa2.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa6.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/dgefa7.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/aijbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact3.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact4.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact5.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact7.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact9.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact11.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/baijfact13.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/bstream/bstream.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/bstream/bstrmfact.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/mpibaij.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/mmbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/baijov.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/bstream/mpibstream.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/seq/dense.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/mpi/mpidense.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/mpi/mmdense.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/mffd.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/mffddef.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/mfregis.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/wp.c.o CMakeFiles/petsc.dir/src/mat/impls/python/pythonmat.c.o CMakeFiles/petsc.dir/src/mat/impls/adj/mpi/mpiadj.c.o CMakeFiles/petsc.dir/src/mat/impls/maij/maij.c.o CMakeFiles/petsc.dir/src/mat/impls/lrc/lrc.c.o CMakeFiles/petsc.dir/src/mat/impls/shell/shell.c.o CMakeFiles/petsc.dir/src/mat/impls/shell/shellcnv.c.o CMakeFiles/petsc.dir/src/mat/impls/normal/normm.c.o CMakeFiles/petsc.dir/src/mat/impls/composite/mcomposite.c.o CMakeFiles/petsc.dir/src/mat/impls/nest/matnest.c.o CMakeFiles/petsc.dir/src/mat/impls/transpose/transm.c.o CMakeFiles/petsc.dir/src/mat/impls/localref/mlocalref.c.o CMakeFiles/petsc.dir/src/mat/impls/blockmat/seq/blockmat.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaij2.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact2.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sro.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact3.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact4.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact5.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact6.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact7.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact8.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact9.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact10.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact11.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbaijfact12.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/aijsbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbstream/sbstream.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/sbstream/sbstrmfact.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/mpisbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/mmsbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/sbaijov.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/mpiaijsbaij.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/sbstream/mpisbstream.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/aij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/aijfact.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/ij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/fdaij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/matmatmult.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/symtranspose.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/matptap.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/matrart.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/inode.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/inode2.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/matmatmatmult.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/bas/basfactor.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/bas/spbas.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/csrperm/csrperm.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/crl/crl.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpiaij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mmaij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpiaijpc.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpiov.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/fdmpiaij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpiptap.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpimatmatmult.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpb_aij.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mpimatmatmatmult.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/csrperm/mpicsrperm.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/crl/mcrl.c.o CMakeFiles/petsc.dir/src/mat/impls/scatter/mscatter.c.o CMakeFiles/petsc.dir/src/mat/order/sp1wd.c.o CMakeFiles/petsc.dir/src/mat/order/spnd.c.o CMakeFiles/petsc.dir/src/mat/order/spqmd.c.o CMakeFiles/petsc.dir/src/mat/order/sprcm.c.o CMakeFiles/petsc.dir/src/mat/order/sorder.c.o CMakeFiles/petsc.dir/src/mat/order/sregis.c.o CMakeFiles/petsc.dir/src/mat/order/degree.c.o CMakeFiles/petsc.dir/src/mat/order/fnroot.c.o CMakeFiles/petsc.dir/src/mat/order/genqmd.c.o CMakeFiles/petsc.dir/src/mat/order/qmdqt.c.o CMakeFiles/petsc.dir/src/mat/order/rcm.c.o CMakeFiles/petsc.dir/src/mat/order/fn1wd.c.o CMakeFiles/petsc.dir/src/mat/order/gen1wd.c.o CMakeFiles/petsc.dir/src/mat/order/genrcm.c.o CMakeFiles/petsc.dir/src/mat/order/qmdrch.c.o CMakeFiles/petsc.dir/src/mat/order/rootls.c.o CMakeFiles/petsc.dir/src/mat/order/fndsep.c.o CMakeFiles/petsc.dir/src/mat/order/gennd.c.o CMakeFiles/petsc.dir/src/mat/order/qmdmrg.c.o CMakeFiles/petsc.dir/src/mat/order/qmdupd.c.o CMakeFiles/petsc.dir/src/mat/utils/convert.c.o CMakeFiles/petsc.dir/src/mat/utils/matstash.c.o CMakeFiles/petsc.dir/src/mat/utils/axpy.c.o CMakeFiles/petsc.dir/src/mat/utils/zerodiag.c.o CMakeFiles/petsc.dir/src/mat/utils/getcolv.c.o CMakeFiles/petsc.dir/src/mat/utils/gcreate.c.o CMakeFiles/petsc.dir/src/mat/utils/freespace.c.o CMakeFiles/petsc.dir/src/mat/utils/compressedrow.c.o CMakeFiles/petsc.dir/src/mat/utils/multequal.c.o CMakeFiles/petsc.dir/src/mat/utils/matstashspace.c.o CMakeFiles/petsc.dir/src/mat/utils/pheap.c.o CMakeFiles/petsc.dir/src/mat/impls/fft/fftw/ftn-auto/fftwf.c.o CMakeFiles/petsc.dir/src/mat/impls/fft/fftw/ftn-custom/zfftwf.c.o CMakeFiles/petsc.dir/src/mat/partition/impls/pmetis/pmetis.c.o CMakeFiles/petsc.dir/src/mat/impls/fft/fftw/fftw.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mumps/ftn-auto/mumpsf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/superlu/ftn-auto/superluf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c.o CMakeFiles/petsc.dir/src/mat/partition/impls/pmetis/ftn-auto/pmetisf.c.o CMakeFiles/petsc.dir/src/mat/partition/impls/scotch/scotch.c.o CMakeFiles/petsc.dir/src/mat/partition/impls/scotch/ftn-auto/scotchf.c.o CMakeFiles/petsc.dir/src/mat/interface/f90-custom/zmatrixf90.c.o CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o CMakeFiles/petsc.dir/src/mat/ftn-custom/zmat.c.o CMakeFiles/petsc.dir/src/mat/color/ftn-custom/zcolorf.c.o CMakeFiles/petsc.dir/src/mat/partition/ftn-auto/partitionf.c.o CMakeFiles/petsc.dir/src/mat/partition/ftn-custom/zpartitionf.c.o CMakeFiles/petsc.dir/src/mat/matfd/ftn-auto/fdmatrixf.c.o CMakeFiles/petsc.dir/src/mat/matfd/ftn-custom/zfdmatrixf.c.o CMakeFiles/petsc.dir/src/mat/coarsen/ftn-auto/coarsenf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-auto/matnullf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-auto/matrixf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-auto/mhasf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-custom/zmatregf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-custom/zmatrixf.c.o CMakeFiles/petsc.dir/src/mat/interface/ftn-custom/zmatnullf.c.o CMakeFiles/petsc.dir/src/mat/impls/submat/ftn-auto/submatf.c.o CMakeFiles/petsc.dir/src/mat/impls/is/ftn-auto/matisf.c.o CMakeFiles/petsc.dir/src/mat/impls/fft/ftn-auto/fftf.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/ftn-auto/baijf.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/seq/ftn-custom/zbaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/ftn-auto/mpibaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/baij/mpi/ftn-custom/zmpibaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/seq/ftn-custom/zdensef.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/mpi/ftn-auto/mpidensef.c.o CMakeFiles/petsc.dir/src/mat/impls/dense/mpi/ftn-custom/zmpidensef.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/ftn-auto/mffddeff.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/ftn-auto/mffdf.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/ftn-auto/wpf.c.o CMakeFiles/petsc.dir/src/mat/impls/mffd/ftn-custom/zmffdf.c.o CMakeFiles/petsc.dir/src/mat/impls/python/ftn-custom/zpythonmf.c.o CMakeFiles/petsc.dir/src/mat/impls/adj/mpi/ftn-auto/mpiadjf.c.o CMakeFiles/petsc.dir/src/mat/impls/adj/mpi/ftn-custom/zmpiadjf.c.o CMakeFiles/petsc.dir/src/mat/impls/lrc/ftn-auto/lrcf.c.o CMakeFiles/petsc.dir/src/mat/impls/shell/ftn-auto/shellf.c.o CMakeFiles/petsc.dir/src/mat/impls/shell/ftn-custom/zshellf.c.o CMakeFiles/petsc.dir/src/mat/impls/normal/ftn-auto/normmf.c.o CMakeFiles/petsc.dir/src/mat/impls/composite/ftn-auto/mcompositef.c.o CMakeFiles/petsc.dir/src/mat/impls/nest/ftn-auto/matnestf.c.o CMakeFiles/petsc.dir/src/mat/impls/transpose/ftn-auto/transmf.c.o CMakeFiles/petsc.dir/src/mat/impls/localref/ftn-auto/mlocalreff.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/ftn-auto/sbaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/seq/ftn-custom/zsbaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/ftn-auto/mpisbaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/sbaij/mpi/ftn-custom/zmpisbaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/ftn-custom/zaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/ftn-auto/aijf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/ftn-custom/zmpiaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/ftn-auto/mpiaijf.c.o CMakeFiles/petsc.dir/src/mat/impls/scatter/ftn-auto/mscatterf.c.o CMakeFiles/petsc.dir/src/mat/order/ftn-auto/sorderf.c.o CMakeFiles/petsc.dir/src/mat/order/ftn-custom/zsorderf.c.o CMakeFiles/petsc.dir/src/mat/utils/ftn-auto/axpyf.c.o CMakeFiles/petsc.dir/src/mat/utils/ftn-auto/gcreatef.c.o CMakeFiles/petsc.dir/src/mat/utils/ftn-auto/getcolvf.c.o CMakeFiles/petsc.dir/src/mat/utils/ftn-auto/multequalf.c.o CMakeFiles/petsc.dir/src/mat/utils/ftn-auto/zerodiagf.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/mpi/mumps/mumps.c.o CMakeFiles/petsc.dir/src/mat/impls/aij/seq/superlu/superlu.c.o CMakeFiles/petsc.dir/src/dm/impls/da/usfft/matusfft.c.o CMakeFiles/petsc.dir/src/dm/impls/da/hypre/mhyp.c.o CMakeFiles/petsc.dir/src/dm/impls/composite/ftn-auto/packf.c.o CMakeFiles/petsc.dir/src/dm/impls/composite/ftn-custom/zfddaf.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexcreatef.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexexodusiif.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexf.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexlabelf.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/plexpointf.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-custom/zcomplex.c.o CMakeFiles/petsc.dir/src/dm/impls/redundant/ftn-auto/dmredundantf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zdaf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zda1f.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zda2f.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zda3f.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zdacornf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zdagetscatterf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zdaindexf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zdaviewf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dacornf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dacreatef.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dadistf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/daf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dageometryf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dagetarrayf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/daghostf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dagtolf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dagtonaf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/daindexf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/dainterpf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/daltolf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/fddaf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/ftn-auto/gr1f.c.o CMakeFiles/petsc.dir/src/dm/impls/adda/ftn-auto/addaf.c.o CMakeFiles/petsc.dir/src/dm/impls/shell/ftn-auto/dmshellf.c.o CMakeFiles/petsc.dir/src/dm/impls/shell/ftn-custom/zdmshellf.c.o CMakeFiles/petsc.dir/src/dm/impls/patch/ftn-auto/patchcreatef.c.o CMakeFiles/petsc.dir/src/dm/interface/ftn-auto/dmf.c.o CMakeFiles/petsc.dir/src/dm/interface/ftn-auto/dmgetf.c.o CMakeFiles/petsc.dir/src/dm/interface/ftn-custom/zdmf.c.o CMakeFiles/petsc.dir/src/dm/interface/ftn-custom/zdmgetf.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/mapping/ftn-auto/aomappingf.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/mapping/ftn-custom/zaomappingf.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/basic/ftn-custom/zaobasicf.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/ftn-auto/aof.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/ftn-custom/zaof.c.o CMakeFiles/petsc.dir/src/dm/impls/composite/pack.c.o CMakeFiles/petsc.dir/src/dm/impls/composite/packm.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/complexcreate.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/complex.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/complexlabel.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/complexexodusii.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/complexvtk.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/plexpoint.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/plexvtu.c.o CMakeFiles/petsc.dir/src/dm/impls/redundant/dmredundant.c.o CMakeFiles/petsc.dir/src/dm/impls/da/da2.c.o CMakeFiles/petsc.dir/src/dm/impls/da/da1.c.o CMakeFiles/petsc.dir/src/dm/impls/da/da3.c.o CMakeFiles/petsc.dir/src/dm/impls/da/daghost.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dacorn.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dagtol.c.o CMakeFiles/petsc.dir/src/dm/impls/da/daltol.c.o CMakeFiles/petsc.dir/src/dm/impls/da/daindex.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dascatter.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dacreate.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dadestroy.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dalocal.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dadist.c.o CMakeFiles/petsc.dir/src/dm/impls/da/daview.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dasub.c.o CMakeFiles/petsc.dir/src/dm/impls/da/gr1.c.o CMakeFiles/petsc.dir/src/dm/impls/da/gr2.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dagtona.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dainterp.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dapf.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dagetarray.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dagetelem.c.o CMakeFiles/petsc.dir/src/dm/impls/da/da.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dareg.c.o CMakeFiles/petsc.dir/src/dm/impls/da/fdda.c.o CMakeFiles/petsc.dir/src/dm/impls/da/grvtk.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dageometry.c.o CMakeFiles/petsc.dir/src/dm/impls/da/dadd.c.o CMakeFiles/petsc.dir/src/dm/impls/da/utils/binaryMatlab.c.o CMakeFiles/petsc.dir/src/dm/impls/sliced/sliced.c.o CMakeFiles/petsc.dir/src/dm/impls/adda/adda.c.o CMakeFiles/petsc.dir/src/dm/impls/shell/dmshell.c.o CMakeFiles/petsc.dir/src/dm/impls/patch/patchcreate.c.o CMakeFiles/petsc.dir/src/dm/impls/patch/patch.c.o CMakeFiles/petsc.dir/src/dm/interface/dm.c.o CMakeFiles/petsc.dir/src/dm/interface/dmregall.c.o CMakeFiles/petsc.dir/src/dm/interface/dmget.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/memscalable/aomemscalable.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/mapping/aomapping.c.o CMakeFiles/petsc.dir/src/dm/ao/impls/basic/aobasic.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/ao.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/dlregisdm.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/aoreg.c.o CMakeFiles/petsc.dir/src/dm/ao/interface/aoregall.c.o CMakeFiles/petsc.dir/src/dm/impls/composite/f90-custom/zfddaf90.c.o CMakeFiles/petsc.dir/src/dm/impls/complex/f90-custom/zcomplexf90.c.o CMakeFiles/petsc.dir/src/dm/impls/da/f90-custom/zdaindexf90.c.o CMakeFiles/petsc.dir/src/dm/impls/da/f90-custom/zda1f90.c.o CMakeFiles/petsc.dir/src/dm/f90-mod/petscdmmod.F.o CMakeFiles/petsc.dir/src/ksp/pc/impls/hypre/ftn-custom/zhypref.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/bitmask.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/comm.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/gs.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/ivec.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/xxt.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/xyt.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/tfs/tfs.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/dgmres/dgmres.c.o CMakeFiles/petsc.dir/src/ksp/f90-mod/petsckspmod.F.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/f90-custom/zitfuncf90.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/bjacobi/ftn-auto/bjacobif.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/bjacobi/ftn-custom/zbjacobif.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/is/ftn-auto/pcisf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/sor/ftn-auto/sorf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/eisens/ftn-auto/eisenf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/wb/ftn-auto/wbf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/ksp/ftn-auto/pckspf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/python/ftn-custom/zpythonpf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/ftn-custom/zluf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/cholesky/ftn-auto/choleskyf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/ftn-auto/factorf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/jacobi/ftn-auto/jacobif.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/galerkin/ftn-auto/galerkinf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/shell/ftn-auto/shellpcf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/shell/ftn-custom/zshellpcf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gasm/ftn-auto/gasmf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/composite/ftn-auto/compositef.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/composite/ftn-custom/zcompositef.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/redistribute/ftn-auto/redistributef.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/ftn-auto/aggf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/ftn-auto/gamgf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/fieldsplit/ftn-auto/fieldsplitf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/asm/ftn-auto/asmf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/asm/ftn-custom/zasmf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/ftn-auto/mgf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/ftn-auto/mgfuncf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/ftn-custom/zmgf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/redundant/ftn-auto/redundantf.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/ftn-auto/pcsetf.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/ftn-auto/preconf.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/ftn-custom/zpcsetf.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/ftn-custom/zpreconf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/rich/ftn-auto/richscalef.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bcgsl/ftn-auto/bcgslf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/gltr/ftn-auto/gltrf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/stcg/ftn-auto/stcgf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/ftn-auto/cgtypef.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/nash/ftn-auto/nashf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/qcg/ftn-auto/qcgf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/ftn-auto/gmpref.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/ftn-auto/gmresf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/fgmres/ftn-auto/modpcff.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cheby/ftn-auto/chebyf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/python/ftn-custom/zpythonkf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/eigef.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/itclf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/itcreatef.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/iterativf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/itfuncf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/itresf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-auto/xmonf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-custom/zitclf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-custom/zitcreatef.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-custom/zitfuncf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-custom/zxonf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/ftn-custom/zdmkspf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/utils/ftn-auto/schurmf.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/hypre/hypre.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/lsc/lsc.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/bjacobi/bjacobi.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/is/pcis.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/is/nn/nn.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/sor/sor.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/pbjacobi/pbjacobi.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/cp/cp.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/eisens/eisen.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/wb/wb.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/ksp/pcksp.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/python/pythonP.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/factor.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/factimpl.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/cholesky/cholesky.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/icc/icc.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/lu/lu.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/factor/ilu/ilu.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/jacobi/jacobi.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/galerkin/galerkin.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/shell/shellpc.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gasm/gasm.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mat/pcmat.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/composite/composite.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/none/none.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/redistribute/redistribute.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/gamg.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/agg.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/geo.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/gamg/tools.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/asa/asa.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/fieldsplit/fieldsplit.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/openmp/hpc.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/asm/asm.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/mg.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/fmg.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/smg.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/mg/mgfunc.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/svd/svd.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/redundant/redundant.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/precon.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/pcset.c.o CMakeFiles/petsc.dir/src/ksp/pc/interface/pcregis.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/symmlq/symmlq.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/tcqmr/tcqmr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/rich/rich.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/rich/richscale.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/tfqmr/tfqmr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bcgsl/bcgsl.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bicg/bicg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/lsqr/lsqr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/lsqr/lsqr_monitor.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/lsqr/lsqr_converged.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/ibcgs/ibcgs.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/cg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/cgeig.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/cgtype.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/gltr/gltr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/cgne/cgne.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/stcg/stcg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/groppcg/groppcg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/nash/nash.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cg/pipecg/pipecg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bcgs/bcgs.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bcgs/fbcgs/fbcgs.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/bcgs/fbcgsr/fbcgsr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/minres/minres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/lcd/lcd.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gcr/gcr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/qcg/qcg.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/preonly/preonly.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/gmres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/borthog.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/borthog2.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/gmres2.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/gmreig.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/gmpre.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/pgmres/pgmres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/fgmres/fgmres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/fgmres/modpcf.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/gmres/lgmres/lgmres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/specest/specest.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cr/cr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cr/pipecr/pipecr.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cgs/cgs.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/cheby/cheby.c.o CMakeFiles/petsc.dir/src/ksp/ksp/impls/python/pythonK.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/itcl.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/itfunc.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/iguess.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/itcreate.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/iterativ.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/itres.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/itregis.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/xmon.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/eige.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/dlregisksp.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/kspams.c.o CMakeFiles/petsc.dir/src/ksp/ksp/interface/dmksp.c.o CMakeFiles/petsc.dir/src/ksp/ksp/utils/schurm.c.o CMakeFiles/petsc.dir/src/ksp/pc/impls/ml/ml.c.o CMakeFiles/petsc.dir/src/snes/interface/noise/snesmfj2.c.o CMakeFiles/petsc.dir/src/snes/interface/noise/snesnoise.c.o CMakeFiles/petsc.dir/src/snes/interface/noise/snesdnest.c.o CMakeFiles/petsc.dir/src/snes/mf/ftn-auto/snesmfjf.c.o CMakeFiles/petsc.dir/src/snes/interface/ftn-auto/snesf.c.o CMakeFiles/petsc.dir/src/snes/interface/ftn-auto/snesutf.c.o CMakeFiles/petsc.dir/src/snes/interface/ftn-custom/zsnesf.c.o CMakeFiles/petsc.dir/src/snes/impls/vi/ftn-auto/vif.c.o CMakeFiles/petsc.dir/src/snes/impls/shell/ftn-auto/snesshellf.c.o CMakeFiles/petsc.dir/src/snes/impls/shell/ftn-custom/zsnesshellf.c.o CMakeFiles/petsc.dir/src/snes/impls/ngmres/ftn-auto/snesngmresf.c.o CMakeFiles/petsc.dir/src/snes/impls/python/ftn-custom/zpythonsf.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/ftn-auto/fasf.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/ftn-auto/fasfuncf.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/ftn-auto/fasgalerkinf.c.o CMakeFiles/petsc.dir/src/snes/impls/qn/ftn-auto/qnf.c.o CMakeFiles/petsc.dir/src/snes/impls/ncg/ftn-auto/snesncgf.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/bt/ftn-auto/linesearchbtf.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.c.o CMakeFiles/petsc.dir/src/snes/linesearch/interface/ftn-auto/linesearchf.c.o CMakeFiles/petsc.dir/src/snes/linesearch/interface/ftn-custom/zlinesearchf.c.o CMakeFiles/petsc.dir/src/snes/interface/f90-custom/zsnesf90.c.o CMakeFiles/petsc.dir/src/snes/f90-mod/petscsnesmod.F.o CMakeFiles/petsc.dir/src/snes/mf/snesmfj.c.o CMakeFiles/petsc.dir/src/snes/utils/dmsnes.c.o CMakeFiles/petsc.dir/src/snes/utils/dmdasnes.c.o CMakeFiles/petsc.dir/src/snes/utils/dmlocalsnes.c.o CMakeFiles/petsc.dir/src/snes/utils/ftn-custom/zdmdasnesf.c.o CMakeFiles/petsc.dir/src/snes/interface/snes.c.o CMakeFiles/petsc.dir/src/snes/interface/snesj.c.o CMakeFiles/petsc.dir/src/snes/interface/snesregi.c.o CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o CMakeFiles/petsc.dir/src/snes/interface/snesj2.c.o CMakeFiles/petsc.dir/src/snes/interface/dlregissnes.c.o CMakeFiles/petsc.dir/src/snes/interface/snesob.c.o CMakeFiles/petsc.dir/src/snes/impls/vi/vi.c.o CMakeFiles/petsc.dir/src/snes/impls/vi/ss/viss.c.o CMakeFiles/petsc.dir/src/snes/impls/vi/rs/virs.c.o CMakeFiles/petsc.dir/src/snes/impls/shell/snesshell.c.o CMakeFiles/petsc.dir/src/snes/impls/gs/snesgs.c.o CMakeFiles/petsc.dir/src/snes/impls/ngmres/snesngmres.c.o CMakeFiles/petsc.dir/src/snes/impls/python/pythonsnes.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/fas.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/fasgalerkin.c.o CMakeFiles/petsc.dir/src/snes/impls/fas/fasfunc.c.o CMakeFiles/petsc.dir/src/snes/impls/ksponly/ksponly.c.o CMakeFiles/petsc.dir/src/snes/impls/tr/tr.c.o CMakeFiles/petsc.dir/src/snes/impls/ls/ls.c.o CMakeFiles/petsc.dir/src/snes/impls/ms/ms.c.o CMakeFiles/petsc.dir/src/snes/impls/qn/qn.c.o CMakeFiles/petsc.dir/src/snes/impls/test/snestest.c.o CMakeFiles/petsc.dir/src/snes/impls/richardson/snesrichardson.c.o CMakeFiles/petsc.dir/src/snes/impls/ncg/snesncg.c.o CMakeFiles/petsc.dir/src/snes/impls/nasm/nasm.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/bt/linesearchbt.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/shell/linesearchshell.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/cp/linesearchcp.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/l2/linesearchl2.c.o CMakeFiles/petsc.dir/src/snes/linesearch/impls/basic/linesearchbasic.c.o CMakeFiles/petsc.dir/src/snes/linesearch/interface/linesearch.c.o CMakeFiles/petsc.dir/src/snes/linesearch/interface/linesearchregi.c.o CMakeFiles/petsc.dir/src/ts/characteristic/impls/da/slda.c.o CMakeFiles/petsc.dir/src/ts/characteristic/interface/characteristic.c.o CMakeFiles/petsc.dir/src/ts/characteristic/interface/mocregis.c.o CMakeFiles/petsc.dir/src/ts/characteristic/interface/slregis.c.o CMakeFiles/petsc.dir/src/ts/interface/ftn-auto/tsf.c.o CMakeFiles/petsc.dir/src/ts/interface/ftn-custom/ztscreatef.c.o CMakeFiles/petsc.dir/src/ts/interface/ftn-custom/ztsf.c.o CMakeFiles/petsc.dir/src/ts/interface/ftn-custom/ztsregf.c.o CMakeFiles/petsc.dir/src/ts/adapt/interface/ftn-auto/tsadaptf.c.o CMakeFiles/petsc.dir/src/ts/impls/python/ftn-custom/zpythontf.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/ssp/ftn-auto/sspf.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/ssp/ftn-custom/zsspf.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/rk/ftn-auto/rkf.c.o CMakeFiles/petsc.dir/src/ts/impls/pseudo/ftn-auto/posindepf.c.o CMakeFiles/petsc.dir/src/ts/impls/arkimex/ftn-custom/zarkimexf.c.o CMakeFiles/petsc.dir/src/ts/impls/rosw/ftn-custom/zroswf.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/alpha/ftn-auto/alphaf.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/theta/ftn-auto/thetaf.c.o CMakeFiles/petsc.dir/src/ts/characteristic/interface/ftn-auto/characteristicf.c.o CMakeFiles/petsc.dir/src/ts/utils/dmts.c.o CMakeFiles/petsc.dir/src/ts/utils/dmdats.c.o CMakeFiles/petsc.dir/src/ts/interface/ts.c.o CMakeFiles/petsc.dir/src/ts/interface/tscreate.c.o CMakeFiles/petsc.dir/src/ts/interface/tsreg.c.o CMakeFiles/petsc.dir/src/ts/interface/tsregall.c.o CMakeFiles/petsc.dir/src/ts/interface/dlregists.c.o CMakeFiles/petsc.dir/src/ts/interface/tseig.c.o CMakeFiles/petsc.dir/src/ts/adapt/impls/cfl/adaptcfl.c.o CMakeFiles/petsc.dir/src/ts/adapt/impls/none/adaptnone.c.o CMakeFiles/petsc.dir/src/ts/adapt/impls/basic/adaptbasic.c.o CMakeFiles/petsc.dir/src/ts/adapt/interface/tsadapt.c.o CMakeFiles/petsc.dir/src/ts/impls/python/pythonts.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/ssp/ssp.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/euler/euler.c.o CMakeFiles/petsc.dir/src/ts/impls/explicit/rk/rk.c.o CMakeFiles/petsc.dir/src/ts/impls/pseudo/posindep.c.o CMakeFiles/petsc.dir/src/ts/impls/arkimex/arkimex.c.o CMakeFiles/petsc.dir/src/ts/impls/rosw/rosw.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/alpha/alpha.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/gl/gl.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/gl/gladapt.c.o CMakeFiles/petsc.dir/src/ts/impls/implicit/theta/theta.c.o CMakeFiles/petsc.dir/src/ts/f90-mod/petsctsmod.F.o  -L/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64  -L/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1/x86_64  -L/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1  -L/usr/llvm-gcc-4.2/lib/gcc  -L/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib/gcc/i686-apple-darwin11/4.2.1  -L/usr/llvm-gcc-4.2/lib  -L/Applications/Xcode.app/Contents/Developer/usr/llvm-gcc-4.2/lib lib/libcmumps.a lib/libdmumps.a lib/libsmumps.a lib/libzmumps.a lib/libmumps_common.a lib/libpord.a lib/libscalapack.a lib/libblacs.a lib/libHYPRE.a lib/libml.a lib/libsuperlu_4.3.a lib/libsuperlu_dist_3.2.a /usr/lib/liblapack.dylib /usr/lib/libblas.dylib /usr/local/lib/libAfterImage.a lib/libtriangle.a /opt/X11/lib/libX11.dylib /Users/barrysmith/Src/ams-dev/lib/libamspub.a lib/libparmetis.dylib lib/libmetis.dylib lib/libfftw3_mpi.a lib/libfftw3.a lib/libptesmumps.a lib/libptscotch.a lib/libptscotcherr.a /usr/lib/libpthread.dylib lib/libyaml.dylib lib/libmpichf90.dylib /usr/local/lib/libgfortran.dylib /usr/local/lib/libgcc_ext.10.5.dylib /usr/local/lib/libquadmath.dylib lib/libmpichcxx.dylib /usr/local/lib/libstdc++.dylib /usr/lib/libm.dylib /usr/lib/libz.dylib lib/libpmpich.dylib lib/libmpich.dylib lib/libopa.dylib lib/libmpl.dylib -framework System /usr/lib/libdl.dylib
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_progress_report /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
[100%] Built target petsc
/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/cmake -E cmake_progress_start /Users/barrysmith/Src/petsc-dev/arch-gnu/CMakeFiles 0
Running /usr/bin/dsymutil on libpetsc
Compilation finished at Thu Dec 13 14:54:46
