[petsc-dev] malloc_dump noise from threadcomm
Sat Dec 8 09:29:22 CST 2012
threadcomm.c has this thing
  for (i=0;i<PETSC_KERNELS_MAX;i++) {
    ierr = PetscNew(struct
_p_PetscThreadCommJobCtx,&PetscJobQueue->jobs[i]);CHKERRQ(ierr);
that gets freed when the last PetscObject gets destroyed. But if the user
forgets to Destroy something, this shows up as a memory leak. Since the
relevant malloc_dump output is much higher in the stack, this is confusing
noise, and I'd like to eliminate it. We can either
1. not log this memory at all by calling malloc or posix_memalign directly
2. put code into PetscFinalize that ensures that this stuff has been freed
(very messy if user does anything weird with communicators)
3. add way to mark PetscTrMalloc'd memory as "indirect" so that it is not
reported by default
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121208/47b44b03/attachment.html>
