[petsc-dev] MatMatSolve_MUMPS
Thu Dec 6 12:25:04 CST 2012
Eric, we would welcome an implementation that batched together a
run-time-specified number of RHS vectors and used MUMPS' native
multiple-RHS routines. The problem is that there has to be enough memory to
store them all on rank 0, which is non-scalable, but the MUMPS developers
do not care to fix that aspect of their interface. The current
implementation solves only one at a time, which is less efficient than
solving several at a time.
On Thu, Dec 6, 2012 at 10:20 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Eric :
> > I just want to know if there is a known difficulty or unfeasible task if
> > someone would like to implement MatMatSolve_MUMPS?
> MatMatSolve_MUMPS is supported in petsc-dev.
> It calls MatMatSolve_Basic() with then calls MatSolve_MUMPS
> in a loop.
> MUMPS own matmatsolve requires entire rhs matrix store in the host
> which is non-scalable.
> Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121206/a8212a6b/attachment.html>
