[petsc-dev] Fwd: rename SNES methods ls, tr etc
Thu Dec 6 10:39:38 CST 2012
On Thu, Dec 6, 2012 at 7:04 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Dec 5, 2012 at 10:36 AM, Anton Popov <popov at uni-mainz.de> wrote:
>> This is not exactly clear to me. Residuals for Dirichlet DOF should be
>> (set to) zero, should they? Because those are not unknowns. What do you mean
>> by Dirichlet boundary residuals?
> If you leave the variables in the vector (convenient for visualization, for
> example) then you have to write residuals for them. With most
> preconditioners, those residuals will be zero after the first iteration, but
> that is not required.
>> Is there any SNES example demonstrating usage of Newton or Picard for a
>> problem with non-zero Dirichlet BC?
> The lid-driven cavity examples do the non-symmetric version. snes ex48 uses
> symmetric version enforcement and could trivially be inhomogeneous. When
> working with external applications, I almost always advocate doing this
> instead of removal or other ad-hoc boundary condition implementations.
> Here is a slightly more formal explanation:
> http://scicomp.stackexchange.com/a/3300/119
I know Jed likes this, but I think it is simpler to think about the problem with
Dirichlet unknowns removed from the solve. We can do both.
   Matt
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
