[petsc-dev] Pipelined CG
Karl Rupp rupp at mcs.anl.gov
Wed Dec 5 11:33:17 CST 2012
Hi Jed,
great, thanks! I think these versions might also work in a multi-GPU
setting, where global synchronization is even more expensive. I should
be able to give that a try soon :-)
Best regards,
Karli
On 12/05/2012 11:08 AM, Jed Brown wrote:
> I just merged several pipelined conjugate gradient methods from Pieter
> Ghysels. If you are interested, here's the paper.
> http://www.exascience.com/wp-content/uploads/2012/12/Ghysels_12.2012.1.pdf
> Access the methods with -ksp_type <pipecg,groppcg,pipecr>
