[petsc-dev] Counting Fortran function pointers
Tue Dec 4 16:43:46 CST 2012
As usual, anything that is duplicated and not checked by the compiler is
broken.
$ grep PetscObjectAllocateFortranPointers src/**/*.c
src/dm/impls/da/ftn-custom/zda2f.c:
 PetscObjectAllocateFortranPointers(*da,6);
src/dm/impls/shell/ftn-custom/zdmshellf.c:
 PetscObjectAllocateFortranPointers(*dm,2);
Note that changing the type does not reset the function pointers, thus
having a DMSHELL, calling DMSetType(dm,DMDA), and then setting a DMDA local
function will cause memory corruption.
I cannot express how much I hate this system. The full-blown solution is
that for each type, we register a (global) token which is the index of that
function pointer. That doesn't have any false dependencies, but is more
"initialize" code.
An alternative, used in the TS and KSP code below, is to have a common enum
that lists all the Fortran functions. It's a false header dependency, but
not a binary dependency.
What should we do? The current state is a disaster.
src/ksp/ksp/impls/gmres/fgmres/ftn-custom/zmodpcff.c:
 PetscObjectAllocateFortranPointers(*ksp,3);
src/ksp/ksp/interface/ftn-custom/zitfuncf.c:
 PetscObjectAllocateFortranPointers(*ksp,FTN_MAX);
src/ksp/pc/impls/mg/ftn-custom/zmgfuncf.c:
 PetscObjectAllocateFortranPointers(*mat,1);
src/ksp/pc/impls/shell/ftn-custom/zshellpcf.c:
 PetscObjectAllocateFortranPointers(*pc,5);
src/mat/impls/mffd/ftn-custom/zmffdf.c:
 PetscObjectAllocateFortranPointers(*mat,2);
src/mat/impls/shell/ftn-custom/zshellf.c:
 PetscObjectAllocateFortranPointers(*mat,11);
src/mat/interface/ftn-custom/zmatrixf.c:
 PetscObjectAllocateFortranPointers(*sp,1);
src/snes/interface/ftn-custom/zsnesf.c:
 PetscObjectAllocateFortranPointers(*snes,14);
src/snes/linesearch/impls/shell/ftn-custom/zlinesearchshellf.c:
 PetscObjectAllocateFortranPointers(*linesearch,3);
src/snes/linesearch/interface/ftn-custom/zlinesearchf.c:
src/sys/draw/utils/ftn-custom/zzoomf.c:
 PetscObjectAllocateFortranPointers(*draw,1);
src/ts/interface/ftn-custom/ztsf.c:
 PetscObjectAllocateFortranPointers(*ts,OUR_COUNT);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121204/c9e943ce/attachment.html>
