[petsc-dev] Matrix Free Conjugate Gradient
Sat Dec 1 00:53:20 CST 2012
On Sat, Dec 1, 2012 at 12:48 AM, Hesameddin Ilatikhameneh <
hilatikh at purdue.edu> wrote:
> Sorry but I didn't get/understand the answer to my questions:
> 1- I don't want to store Jacobian matrix so how is that Mat A is input of
> the function PetscErrorCode YourMatMult(Mat A,Vec X,Vec Y)?
That Mat has type MATSHELL. It contains no data (or only the data you put
there). You are implementing the Mat interface as you like.
> 2- I need to find each row of Jacobian and multiply it with a vector which
> is needed in Petsc CG and store that to a vector. So there should be very
> specific function associated with specific method (like CG in this case).
You just need to apply your operator to the Vec. Most matrix-free operators
never explicitly construct entries of the matrix. (Other matrix-free
operators include matrix-free finite difference, FFT, FMM, tensor product
operations, unassembled Galerkin products, and approximate Schur
complements.)
> 3- What is vector X in YourMatMult(Mat A,Vec X,Vec Y)?
It's the Vec that's passed in. You use the Vec interface (VecGetArray, etc)
to interact with it.
> Where this matrix-multipication will be used?
When CG (or any other method) needs to apply the matrix.
> Thanks
> Hesam
> From: "Jed Brown" <jedbrown at mcs.anl.gov>
> To: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov
> Sent: Saturday, December 1, 2012 1:08:59 AM
> Subject: Re: [petsc-dev] Matrix Free Conjugate Gradient
> On Fri, Nov 30, 2012 at 11:53 PM, Hesameddin Ilatikhameneh <
> hilatikh at purdue.edu > wrote:
> Could you provide more information/example.
> I don't know that for example for matrix-free conjugate gradient in Petsc
> which matrix operation I should do.
> I guess that I need to write the function that gives Jacobian times a
> vector which is vector (Since I don't want to store Jacobian).
> If it is so, which vector is that vector? Petsc will do which parts of the
> algorithm?
> You implement
> PetscErrorCode YourMatMult(Mat A,Vec X,Vec Y);
> which computes Y <-- A*X. There is a section of the user's manual, as well
> as a couple examples linked from the page I sent.
> You only need to implement that one function, then pass -pc_type none so
> that no preconditioning is done. PETSc will do everything else in the solve.
> Thanks for your help.
> Hesam
> From: "Jed Brown" < jedbrown at mcs.anl.gov >
> petsc-dev at mcs.anl.gov >
> Sent: Saturday, December 1, 2012 12:37:22 AM
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatShellSetOperation.html
> Note that without an assembled matrix, you'll generally need to write your
> own preconditioner, which you can do using PCShell.
> On Fri, Nov 30, 2012 at 11:24 PM, Hesameddin Ilatikhameneh <
> Hello,
> We have a very large system (100M variables) which we want to minimize its
> energy. We are using Petsc extensively for matrix operations.
> I know that it is theoretically possible to use conjugate gradient method
> without storing Jacobian matrix (which is very huge in this case) since the
> conjugate gradient needs Jacobian times a vector not Jacobian itself.
> I read your manual about matrix free methods but I couldn't find where I
> can determine that function to Jacobian times a vector.
> I appreciate your help.
> Thanks
> Hesam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121201/605eca30/attachment.html>
