[petsc-dev] Ghost values in sieve
Chris Eldred chris.eldred at gmail.com
Thu Aug 23 12:26:13 CDT 2012
Yes- I am implementing the TriSK scheme
(www.mmm.ucar.edu/people/skamarock/Ringler_et_al_JCP_2009.pdf) on
arbitrary Voronoi meshes. In order to do wind/flux reconstruction at
the cell edges, it needs to know about the edges of adjacent cells-
which are outside of closure(p) U star(p).
On Thu, Aug 23, 2012 at 11:16 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Aug 23, 2012 at 12:12 PM, Chris Eldred <chris.eldred at gmail.com>
> wrote:
>> Thanks- that helps a lot. If I need stencils that are larger than
>> closure(p) U star(p) (for a higher-order finite difference method, for
>> example), I assume that I need to create my own PetscSF's that
>> describe which points need to be ghosted?
> Is this still a fully unstructured method? The Sieve formalism doesn't give
> you a very efficient way to do this for structured or semi-structured grids.
> Even so, if wider stencils are to be supported, I think it should be
> implemented within the library. Doing it outside with the current
> infrastructure is going to be quite a rabbit hole.
>> Is there some documentation or example code that explains the theory
>> behind star forests?
> Docs for the basic operations:
> http://59A2.org/files/StarForest.pdf
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
