[petsc-dev] [petsc-maint #129715] __float128 complex
Thu Aug 23 11:27:05 CDT 2012
On Thu, 23 Aug 2012, Jose E. Roman wrote:
> Anyway, it would be a good opportunity to upgrade to Lapack 3.4 (the
> toclapack.sh script should work for this version as well).
Ok. Will do this. Hower I see a bunch of embeded code in toclapack.sh
- corresponding to different lapack versions. Would this be a problem?
Satish
asterix:/home/balay/spetsc/bin/maint>grep -i version toclapack.sh |grep LAPACK
/*  -- LAPACK auxiliary routine (version 3.3.0) -- */
/*  -- LAPACK auxiliary routine (version 3.0) --
/*  -- LAPACK routine (version 3.2.2) -- */
#/*  -- LAPACK auxiliary routine (version 3.1) -- */
