[petsc-dev] Problem mixing sieve and TS
Paul Sicsic paul.sicsic at polytechnique.edu
Thu Oct 27 00:30:34 CDT 2011
Yes ex22f runs correctly.
We have tested this on different architectures (ubuntu, darwin) and
compilers (intel, gcc).
2011/10/27 Jed Brown <jedbrown at mcs.anl.gov>
> On Wed, Oct 26, 2011 at 23:09, Paul Sicsic <paul.sicsic at polytechnique.edu>wrote:
>>    - The dot variable is still Nan when trying to compute the IFunction.
>>    - These options seem to still be giving a shift that is infinity when
>>    computing the IJacobian. (In step 0 here)
>> Yeah, this is the problem, but I can't reproduce it for other problems.
> With these symptoms, I would expect memory corruption or a build/link error.
> Can you confirm that the examples run correctly?
PS
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111027/42b06b8f/attachment.html>
