[petsc-dev] I hate Mecurial
Barry Smith
bsmith at mcs.anl.gov
Sat Oct 8 12:40:57 CDT 2011
On Oct 8, 2011, at 12:36 PM, Sean Farley wrote:
> What the fuck? Why cannot it not provide some useful information on what I need to do?????? This absolutely sucks!!!!
> "abort: outstanding uncommitted changes"
> First, you need to update mercurial to 1.9.3. Then try and see if that works better. Alternatively, you can try the shelve or attic extensions:
The first answer out of Sean's mouth whenever something goes wrong with Mecurial is shelve/attic, why am I not surprised.
Now I ignore the answer because I actually have no uncommitted changes and don't want to shelve or attic anything.
Now I wait for next knee-jerk response from Mecurial lovers/haters. Knowing again it is likely unhelpful.
Barry
> $ hg pull
> $ hg merge
> $ hg shelve
> $ hg st
> $ hg merge
> $ hg ci
> $ hg unshelve
> or something like that. Depending if you install shelve or attic will change the commands slightly.
