[petsc-dev] VECCUSP needs to be zeroed?
Lisandro Dalcin dalcinl at gmail.com
Wed Nov 9 13:58:19 CST 2011
On 9 November 2011 16:50, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Nov 9, 2011 at 13:42, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> But then, what's the point of memzeroing in VecCreate_Sec? Wouldn't it
>> be better to fill the array (in debug mode) with signaling NaNs ?
> I'm not opposed to this.
> There is a question of how much we want to be tolerant of sloppy users
> versus being strict within the library. I think the tactic above (and/or
> simply leave it uninitialized and count on valgrind to let us know) would be
> good to use in PETSc tests.
OK. I was not taking valgrind into account.
> I'm not sure it's worth pushing on users as the
> default.
What tactic? Leave entries uninitialized? I'm just asking for PETSc to
behave consistently. If CPU memory is zeroed when Vecs are created,
the same should happen for GPU memory.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
