[petsc-dev] PCFieldSplit broken, what was intended?
Jed Brown jed at 59A2.org
Fri May 27 11:44:57 CDT 2011
On Fri, May 27, 2011 at 18:35, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I quick and dirty fix would be to add a reset flag into PC_Fieldsplit and
> then do this block of code only if that reset flag is true then turn off the
> reset flag.
What about putting that block of code in a different function and calling it
directly from PCReset_FieldSplit()?
>     BTW: once we have PetscLayout containing field information we should
> totally rewrite the PCFIELDSPLIT to simplify and rationalize it,
Yes, absolutely.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110527/1435fd34/attachment.html>
