[petsc-dev] attaching field information to PetscLayout?
Jed Brown jed at 59A2.org
Sat May 14 16:46:42 CDT 2011
On Sat, May 14, 2011 at 23:33, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> That would also be convenient if a Vec and a Mat shared the layout
> (Mat's cmap), because then they automatically have
> compatible splits and/or localtoglobalmappings.  Recently, however, I
> became convinced that l2gmappings, as they are now,
> are not adequate for some more advanced tasks, such as splitting of
> matrices/vectors into overlapping pieces.
How so? MatGetLocalSubMatrix() does this right now (sort of, the values are
not guaranteed to be available because its primary purpose is for assembly).
Or do you mean getting overlapping pieces based on the global ordering and
then having local spaces automatically defined? I'm not sure that makes
semantic sense. If IS had the information about the local space that is in
PetscLayout+ISLocalToGlobalMapping, than MatGetSubMatrix() could include the
local space.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110514/bb1b21a2/attachment.html>
