[petsc-dev] attaching field information to PetscLayout?
Jed Brown jed at 59A2.org
Sat May 14 15:37:57 CDT 2011
On Sat, May 14, 2011 at 22:35, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Inside PetscLayout? Token generation then has to beat direct IS matching.
I assumed the tokens would be a property of IS (or perhaps even
PetscObject). Token generation would only be done once when the IS is
created.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110514/85e7f666/attachment.html>
