[petsc-dev] attaching field information to PetscLayout?
Jed Brown jed at 59A2.org
Sat May 14 15:36:14 CDT 2011
On Sat, May 14, 2011 at 22:31, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Via Vec/MatSetValuesLocal?  I would agree with that.
> What I don't like about that is that now there will be two different
> ways of treating splits that happen to be nonoverlapping:
> via some clever XXXSetValuesLocal and via the nonoverlapping splits
> mechanism inside PetscLayout.
I think MatSetValuesLocal() should be the canonical way to modify "part" of
a Mat. For Vec, you can get a local vector to modify with array access or
use VecSetValuesLocal() depending on your needs. Top-down addressing
requires some amount of global knowledge and it makes information flow in an
unnatural way (for code and for performance).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110514/2435feec/attachment.html>
