[petsc-dev] attaching field information to PetscLayout?
Jed Brown jed at 59A2.org
Sat May 14 15:32:09 CDT 2011
On Sat, May 14, 2011 at 22:26, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> So the splits are identified by the IS (e.g., "give me the subvec
> corresponding to the split with this IS")?
Yes, that is VecGetSubVector(Vec,IS,Vec*).
> I assume that will require IS matching.  Is that faster than string
> matching (I guess it depends on the string/IS length/type).
That depends on the Vec implementation and IS. I think there are many places
where we would like IS matching (all the submatrix stuff, for example). IS
is (almost) immutable at this point, therefore we can create a unique token
for each IS. Then looking up an IS becomes a single hash lookup.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110514/5bd8e562/attachment.html>
