[petsc-dev] petsc shared libraries on cygwin?
Brad Aagaard baagaard at usgs.gov
Wed May 11 21:30:37 CDT 2011
Under what conditions (configure args), if any, will petsc-dev build a
shared library on cygwin? I am getting static libraries which are
causing linking problems when trying to build python modules that use
petsc.
Lisandro- Do you build petsc4py on cywgin? If so, how do you configure
petsc and mpi?
Brad
