[petsc-dev] CMake broken
Wed May 11 08:05:07 CDT 2011
   That is my fault. I messed with that SUBPROCESS file a long time ago and forgot I changed it, then when I put in proper changes I left that bad change.
    Satish, can you remove the comment of the subprocess stuff and push?
    Thanks
    Barry
On May 11, 2011, at 7:51 AM, Jose E. Roman wrote:
> CMake build is broken in the latest petsc-dev: cmakeboot does not generate the makefiles.
> I have made a bisection search and found this changeset in BuildSystem:
> http://petsc.cs.iit.edu/petsc/BuildSystem/rev/bbad23803405
> If I uncomment the line USE_SUBPROCESS = 0 in config/Buildsystem/script.py then it works again.
> Jose
