[petsc-dev] two quick questions on Fortran style/includes
Tue May 10 13:03:45 CDT 2011
added now.
satish
On Tue, 10 May 2011, Barry Smith wrote:
>    Satish,
>      Please apply this patch.
>      Thanks
>    Barry
> On May 10, 2011, at 11:46 AM, Ethan Coon wrote:
> > 1. Is there a reason that both .F and .F90 examples are in fixed format,
> > even though .F90 files should be interpreted as free format?  I guess
> > the fixed format works for either a fixed/free compiler, but it's ugly.
> > I wouldn't be surprised if there was a portability issue with free
> > format .F90 files, so I figured I'd check.
> > 2. Is there a reason PETSC_SCALAR is defined in finclude/petscsysdef.h,
> > but PETSC_REAL is not?  Using PETSC_USE_FORTRAN_MODULES and "use petsc",
> > I get implicit declaration errors when using PETSC_REAL (but
> > PETSC_SCALAR is defined as expected).
> > The below patch fixes this issue, assuming I'm not missing something...
> > diff -r b702b1062e33 include/finclude/petscsysdef.h
> > --- a/include/finclude/petscsysdef.h	Mon May 09 15:26:40 2011 -0600
> > +++ b/include/finclude/petscsysdef.h	Tue May 10 10:41:35 2011 -0600
> > @@ -115,7 +115,14 @@
> > #define PETSC_SCALAR PETSC_LONG_DOUBLE
> > #elif defined(PETSC_USE_REAL_DOUBLE)
> > #define PETSC_SCALAR PETSC_DOUBLE
> > -#endif
> > +#endif
> > +#endif
> > +#if defined(PETSC_USE_REAL_SINGLE)
> > +#define  PETSC_REAL  PETSC_FLOAT
> > +#elif defined(PETSC_USE_REAL_LONG_DOUBLE)
> > +#define  PETSC_REAL  PETSC_LONG_DOUBLE
> > +#else
> > +#define  PETSC_REAL  PETSC_DOUBLE
> > #endif
> > !     Macro for templating between real and complex
> > Ethan Coon
> > Post-Doctoral Researcher
> > Applied Mathematics - T-5
> > Los Alamos National Laboratory
> > 505-665-8289
> > http://www.ldeo.columbia.edu/~ecoon/
