[petsc-dev] what happened to information about setting -display DISPLAY etc and getting it to work?
Jed Brown jed at 59A2.org
Thu Mar 31 08:50:31 CDT 2011
On Thu, Mar 31, 2011 at 16:48, Jed Brown <jed at 59a2.org> wrote:
> no need to always -display :0 to sign in
umm, typed in wrong text box. No need to use -display :0 on most systems,
and DISPLAY from rank 0 is propagated if not set otherwise. Do you have a
case where it is failing?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110331/169ba4a9/attachment.html>
