[petsc-dev] generatefortranstubs.py cannot run concurrently
Jed Brown jed at 59A2.org
Sat Mar 26 14:15:26 CDT 2011
On Sat, Mar 26, 2011 at 21:20, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I thought of that. But it takes seconds to build and it could be a later
> run did come after some change to the files so see no harm in rebuilding. If
> setting up the locking mechanism is as messy as doing them in parallel we
> might as well do them in parallel.
Seems to me that we should write dependencies for those sources and rebuild
exactly when they are out of date. One option is to generate them out of the
source tree and then move them in atomically. Then it won't matter if
concurrent processes occasionally duplicate a small amount of the same work.
Note that we pay significantly more to recompile those sources than to
generate the fortran stubs.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110326/be7125fa/attachment.html>
