[petsc-dev] subrepositories
Jed Brown jed at 59A2.org
Thu Mar 24 16:49:46 CDT 2011
Barry, could you explain what is so wrong about subrepos and what semantics
you desire?
On Fri, Mar 25, 2011 at 00:02, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Satish explained how hg sub repositories work. They are moronic, we don't
> want to use them.
>    Is there any way with "triggers" or some other technique to rig it so if
> I do hg xxx in petsc-dev it automatically runs it also in BuildSystem. For
> example hg pull triggers a pull in both petsc-dev and BuildSystem?
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110325/879fe39b/attachment.html>
