[petsc-dev] Problem with SNES and FieldSplit
Tue Mar 15 18:03:07 CDT 2011
On Tue, Mar 15, 2011 at 6:00 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Mar 15, 2011 at 23:50, Matthew Knepley <knepley at gmail.com> wrote:
>> That is not what I have here. I want to change a portion, but outside of
>> that I want it to fall back to a global matrix.
> You were going to put your MatShell in the "pmat" slot, right? What are you
> going to use for preconditioning the other blocks? If it's the same as in
> "mat", you could use a MatNest for both operators and put the special sauce
> in that slot of the "pmat".
This is the same objection Barry has. I do not want this tied to a
particular matrix impl for the global matrix.
> If you assemble the matrix entirely monolithically (using MatSetValues
> globally instead of MatSetValuesLocal on each physics separately), then we
> haven't written MatSetValues_Nest yet so maybe your MatShell is the right
> idea.
> Related: What do people think about having MatGetSubMatrix() retain
> ownership of the submatrix?
Does it matter with our interface? Should be transparent.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/f77389fc/attachment.html>
