[petsc-dev] Problem with SNES and FieldSplit
Tue Mar 15 17:50:45 CDT 2011
On Tue, Mar 15, 2011 at 5:41 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Mar 15, 2011 at 23:33, Matthew Knepley <knepley at gmail.com> wrote:
>> If it does exactly what I just said, I will. However, from my reading, it
>> does not.
> You can do it with MatNestGetSubMats(), modify one entry,
> MatNestSetSubMats(). But if you plan to do this often, add
> MatNestUpdateSubMat(). Hmm, seems like MatNestGetSubMats() should return the
> row and column ISs for symmetry.
That is not what I have here. I want to change a portion, but outside of
that I want it to fall back to a global matrix.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/7d26858a/attachment.html>
