[petsc-dev] JSON library
Blaise Bourdin bourdin at lsu.edu
Mon Mar 14 16:19:35 CDT 2011
On Mar 14, 2011, at 4:04 PM, Jed Brown wrote:
> I want to reiterate a statement I made a while back that any alternative input format really needs to support references. This is a good reason to prefer Yaml over JSON. Yaml is a superset of JSON, but offers a more readily human-readable layout, example: http://www.yaml.org/start.html
> The important feature here is that references can be reused so it becomes possible to define multiple solver configurations, then use each one (perhaps with local modifications) in multiple places or not at all. If you just do plain JSON, it's essentially the same expressiveness as current options files, albeit easier to manipulate from other languages.
I fully agree on the principle, but the scope is beyond what I can reasonably get done in a limited time.
To me, "easier to manipulate from other languages" is already a huge improvement. I have folders with 100's of computations corresponding to different sets of parameters. I need an easier way to import these simulation parameters in scripts. And I need it yesterday, not next year.
To be honest windows style .ini files would be fine for what I need to do. JSON is just a bit more hip.
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110314/0748616a/attachment.html>
