[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
Lisandro Dalcin dalcinl at gmail.com
Thu Mar 10 18:57:23 CST 2011
On 10 March 2011 21:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 10, 2011, at 6:22 PM, Lisandro Dalcin wrote:
>> On 10 March 2011 20:57, Ethan Coon <ecoon at lanl.gov> wrote:
>>> Attached patch makes this change, and updates the website with the API
>>> change.
>>> Also it fixes a few stray 'DAPeriodicType's in conf/adic*.init, which
>>> I'm guessing was just missed in the previous change to DMDAPeriodicType?
>> Do we really need backward compatibility DMDA_XYZPERIODIC and friends?
>  Is the | business all fine and dandy for Fortran? If so then I agree we should remove the "noise".
Well, you can use '+' (with a bit care) in any Fortran, right?. This
is the way the MPI standard does things for some enumerations (file
modes, RMA assertions).
However, if DMDA_XYZPERIODIC and friends do no go away because of
Fortran issues, then we should definitely define
DMDA_{XY|XZ|YZ}GHOSTED.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
