[petsc-dev] make test failure
Thu Mar 3 22:03:46 CST 2011
this shortcut doesn't help. send logs to petsc-maint.
satish
On Thu, 3 Mar 2011, Mike McCourt wrote:
> Hey guys, I just built petsc-dev I think it went through fine, but when I did the make test I got
> laptop:~/argonne/petsc-dev$ make PETSC_DIR=/home/ironmike/argonne/petsc-dev PETSC_ARCH=linux-facets test
> Running test examples to verify correct installation
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
> See http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html
> ssh: connect to host localhost port 22: Connection refused
> Unknown signal 112 (signal 112)
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes
> Error running Fortran example src/snes/examples/tutorials/ex5f with 1 MPI process
> Completed test examples
> My petsc-3.1-p7 still works fine.  I know I should send the configure.log and make.log, but I figured I'd send this to the dev list first in case there was a quick fix.
> Thanks,
> -Mike
