[petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
Philip, Bobby philipb at ornl.gov
Tue Jun 7 12:18:43 CDT 2011
Boyce:
I recognize the benefits and we should talk about this more. In my case I do have my own data types too for interlaced data
and it would be nice to have it all work well. As you know, it's non trivial maintaining all this.
The reason this whole conversation started was difficulties in trying to keep PFLOTRAN, SAMRAI, and PETSc in sync.
Bobby
Sent: Tuesday, June 07, 2011 1:05 PM
To: For users of the development version of PETSc
Cc: Philip, Bobby
Subject: Re: [petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
On 6/7/11 12:48 PM, Bobby Philip wrote:
> On Jun 6, 2011, at 4:26 PM, Boyce Griffith wrote:
>> What I'd really like to do is to setup some SAMRAI stuff that actually
>> uses Vec / Mat for data storage, so that most of this wrapper stuff is
>> not necessary.  (It would probably still be necessary to have a wrapper
>> for VecNorm, but that might be the only one.)  Of course, I've been
>> wanting to do this for years now...
> Setting it up to use PETSc storage would probably break a lot of my code and PFLOTRAN.
Not that I have the time to do this right now, but the idea would be to
do most/all of this "behind the scenes," so that application codes that
use standard SAMRAI PatchData types would work without modification.
One benefit of doing this could be easier access to different smoothers
for use in FAC; or to other composite-grid solvers for problems where
FAC is not necessary.  Another might be easier access to CUDA.
-- Boyce
