[petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
Bobby Philip philipb at ornl.gov
Tue Jun 7 11:47:00 CDT 2011
> All I can tell you is that, many years ago, at least some of these calls
> to PetscObjectStateIncrease() were needed in the Vec routines in order
> to get PETSc solvers to work with the SAMRAI PETSc Vec class.  To try to
> avoid the issues that Bobby is reporting, I went ahead and made any Vec
> routine that could conceivably result in an invalidation of cached Vec
> data call PetscObjectStateIncrease().  I probably went overboard and
> call it unnecessarily in some places.
I followed a very similar strategy.
> I will work on systematically removing these calls and report any problems.
> Besides nonlinear function evalutations, is it also necessary in
> implementations of MatVecMult/MatVecMultAdd/etc?  Or should these also
> be handled automatically by PETSc?
Again, these exist on AMR grids as part of some the PFLOTRAN work - Boyce
I can share if you are interested.
> Thanks,
> -- Boyce
