[petsc-dev] valgrind appears to show memory leak related to PetscViewerBinaryOpen
Jed Brown jed at 59A2.org
Wed Jun 1 11:23:53 CDT 2011
On Wed, Jun 1, 2011 at 18:20, Barry Smith <bsmith at mcs.anl.gov> wrote:
> There is no reason for the existence of PetscViewerBinaryCreate(), I am
> removing it from PETSc-dev.
Are you also removing MatCreateSeqAIJ()? Removing it turns one line into
four and I don't see the benefit. I suspect people are less likely to use
-viewer_type to change their viewer than -mat_type to change their matrix.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/da028ad0/attachment.html>
