[petsc-dev] MPI Vec and HDF5 output
Brad Aagaard baagaard at usgs.gov
Fri Jan 28 10:23:12 CST 2011
We are trying to get HDF5 output working in PyLith using the PETSc HDF5
viewer. I get an HDF5 error
H5Screate_simple(): zero sized dimension for non-unlimited dimension,
VecView_MPI_HDF5() line 771 in petsc-dev/src/vec/vec/impls/mpi/pdvec.c
when I have a Vec that has a zero local size on a processor (the global
size is nonzero). The Vec layout is correct in that we expect some
processors to have a local size of zero (the field is over only a
portion of the domain).
The collective write of the Vec creates the filespace using the global
size and the memspace using the local size. It is in trying to create
the memspace that the error occurs. I tried adjusting pdvec.c so that it
creates a null memspace when the local size is zero but then I get an
error during the write about differences in dimensions (the number of
dimensions in the filespace and memspace don't agree). I was unable to
find any info on this type of use case in the HDF5 documentation.
I have attached a toy example that illustrates the problem.
mpiexec -n 1 test_view [creates the expected test.h5 file]
mpiexec -n 2 test_view [generates the above error]
Brad
Type: application/x-gtar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110128/5a5bc5fa/attachment.gtar>
