[petsc-dev] broke configure removed config.guess and config.sub
Thu Jan 27 15:58:12 CST 2011
On Thu, Jan 27, 2011 at 3:55 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Mat,
> Since ftp is working but not http - as a workarround you could try for eg:
> ./configure --download-f-blas-lapack=
> ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/f2cblaslapack-3.1.1.a.tar.gz
Cool, I did not know that worked. We need to have failover it sounds like.
   Matt
> Satish
> On Thu, 27 Jan 2011, Matthew Knepley wrote:
> > How about lighting a fire under those fuckers at systems so I can
> > reconfigure? FTP has
> > been down all day.
> >    Matt
> > On Thu, Jan 27, 2011 at 3:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >   Matt and everyone
> > >    I have intentionally partly broken configure by removing ALL traces
> of
> > > the use of the two horrible horrible bash shell scripts config.guess
> and
> > > config.sub that should have been removed a decade ago and make
> configure
> > > work only on Unix.
> > >   This will break sharedLibraries.py that used hostOSBase which
> computed
> > > using host_os and TetGen.py and Triangle.py that for some strange
> reason
> > > also use it. Best to get rid of hostOSbase completely and do proper
> tests
> > > for different ways of making shared libraries.  Until this is fixed
> > > sharedlibraries won't work.
> > >   Please report or fix all problems that come up ASAP.
> > >   Barry
> > > Yes be pissed at me for ruining your day, but I'm finally lighting the
> fire
> > > under bad configure practices that make it only work on Unix. Cygwin
> usage
> > > must die!
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110127/75e83c63/attachment.html>
