[petsc-dev] XXXDestroy() mistaken design in PETSc
Tue Feb 15 20:03:22 CST 2011
  This also applies to PetscFree()
On Feb 15, 2011, at 4:47 PM, Barry Smith wrote:
>  In MPI one calls MPI_Comm_free(&comm) to allow the MPI implementation to set the pointer explicitly to 0 after the object is destroyed.
>  In Petsc XXXDestroy() does not pass the pointer (because it seemed too unnatural to me in 1994) thus not allowing 0ing the pointer.
>   Was this a bad design decision? Should it be revisited?
>   Barry
>  Two use cases
> 1) error detection when someone tries to reuse a freed object
> 2) when removing some objects from a data structure that will be used data one currently needs to do
>  XXXXDestroy(mystruct->something);CHKERRQ(ierr); mystruct->something = 0;
> instead of the cleaner XXXDestroy(&mystruct->something);CHKERRQ(ierr);
