[petsc-dev] XXXDestroy() mistaken design in PETSc
Tue Feb 15 16:47:35 CST 2011
  In MPI one calls MPI_Comm_free(&comm) to allow the MPI implementation to set the pointer explicitly to 0 after the object is destroyed.
  In Petsc XXXDestroy() does not pass the pointer (because it seemed too unnatural to me in 1994) thus not allowing 0ing the pointer.
   Was this a bad design decision? Should it be revisited?
   Barry
  Two use cases
1) error detection when someone tries to reuse a freed object
2) when removing some objects from a data structure that will be used data one currently needs to do
  XXXXDestroy(mystruct->something);CHKERRQ(ierr); mystruct->something = 0;
instead of the cleaner XXXDestroy(&mystruct->something);CHKERRQ(ierr);
