[petsc-dev] [petsc-maint #64229] Re: PetscExceptionTry1
Mon Feb 14 14:15:28 CST 2011
On Feb 14, 2011, at 2:14 PM, Jed Brown wrote:
> On Mon, Feb 14, 2011 at 21:12, Jed Brown <jed at 59a2.org> wrote:
>> somehow otherwise communicating through the file system
> Maybe running PETSc on a subcomm with some proprietary or high-inertia code
> on a different communicator? IIRC, there are some climate models that
> "couple" using the file system.
  Insane :-(
> Maybe running PETSc on a subcomm with some proprietary or high-inertia code on a different communicator? IIRC, there are some climate models that "couple" using the file system.
