[petsc-dev] PETSC_DIR/.dir-locals.el
Mon Feb 7 14:12:57 CST 2011
Folks,
If you get a message of the following type - when loading any
petsc-dev sourcefile in emacs - the appropriate thing to do is choose
'!' from below. [and the message won't come up again]
Satish
The local variables list in /home/balay/petsc-dev/
contains values that may not be safe (*).
Do you want to apply it?  You can type
y  -- to apply the local variables list.
n  -- to ignore the local variables list.
!  -- to apply the local variables list, and permanently mark these
      values (*) as safe (in the future, they will be set automatically.)
    indent-tabs-mode : nil
    tab-width : 8
  * show-trailing-whitespace : t
