[petsc-dev] PaStiX solution
Alexander Grayver agrayver at gfz-potsdam.de
Wed Dec 28 03:52:32 CST 2011
Hello dev-team,
I wrote simple program to test different solvers. It reads matrix and
rhs and solves system. That is it.
I tested this program using PETSc's interface to MUMPS (LDLt),
SuperLU_Dist (LU) and it works well giving right solution, however when
I switch
to PaStiX (LLt) the solution is zero. The output is attached.
The matrix is SPD and has condition number of 16, there should be no
problem.
I use petsc-dev.
How could I figure out where is the problem?
Thanks in advance.
Alexander
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111228/c723aa37/attachment.txt>
