[petsc-dev] features of GAMG
Mon Dec 26 09:41:18 CST 2011
On Mon, Dec 26, 2011 at 00:07, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Can you show me an example? I have certainly seen it make a different for
> other problems.
> OK, well we need to think about this then.  Maybe we can take a look at it
> at Brown in January.  There must be some bad interaction in the way that
> I'm using it.  The code is around 662 in gamg.c.
Can you tell me how to run an example that shows this behavior?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111226/0e505636/attachment.html>
