[petsc-dev] Non-scalable matrix operations
Fri Dec 23 13:39:22 CST 2011
On Fri, Dec 23, 2011 at 13:37, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Also, my algorithm exploits static partitions where you know who is
> processing your ghost nodes (so you can avoid stepping on each other).
>  This might not be available.  Coloring looks OK for 7 point stencils but
> the number of colors gets very large at higher order.  You need about 13
> colors for a 3D hex mesh (not very high order at all).  But inside the
> compute node there are sets of vertices that need processing and you can do
> whatever you want on these sets, so if you need to color then so be it.
I think the number of colors is pretty much hopeless if you use a stable
Stokes element like Q2-P1disc.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/411ac501/attachment.html>
