[petsc-dev] Non-scalable matrix operations
Fri Dec 23 13:20:28 CST 2011
On Fri, Dec 23, 2011 at 12:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Dec 23, 2011 at 12:27, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> A more interesting thing is partition down to the thread level and keep
>> about 100 vertices per thread (this might be to big for a GPU...)
> It's fine to have more partitions than threads.
>> and then use locks of some sort for the shared memory synchronization
> It can be lock-free, your thread just waits until a buffer has been marked
> as updated. Since the reader/writer relationships are predefined, it's not
> actually a lock. (You can do more general methods lock-free too.)
You could use
  a) coloring and stream events (easy)
  b) what John Cohen does which I still do not understand
We should talk to him
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/c4fe687b/attachment.html>
