[petsc-dev] Non-scalable matrix operations
Fri Dec 23 01:01:53 CST 2011
Can we enumerate the matrix operations that are known to be non-scalable
currently?
1. MatPermute() does ISAllGather() on the row indices and requires the user
to ISAllGather() the column indices before calling (I consider this to be
an interface bug similar to the MatGetSubMatrix() one we fixed before
petsc-3.1). The problem is that we have to determine the new row and column
or each locally visible row and column. This would be equivalent to having
a scalable ISInvertPermutation(), which is not difficult to implement, and
a way to retrieve data from off-process (new column indices for the "B"
part). The latter can be done with a "VecScatter for integers", or
trivially with PetscBG (name subject to change).
2. MatGetSubMatrix(), also called by MatPermute(). For this, it is
sufficient to determine where each currently owned entry should go (or be
skipped). We could do this by making a parallel int-vector for the entire
column space, setting it all to -1, then pushing the "new" column index
(location in the IS) over the IS. This gives a parallel vector that is -1
for all column indices we don't want and the non-negative new column index
for those that we do want. Now we retrieve from the parallel vector
everything we need for the local column space.
3. MatIncreaseOverlap_MPISBAIJ(), I haven't looked carefully.
I'm writing MatConvert_Nest_AIJ() which needs a similar feature. Mark wants
parallel MIS and MOOSE wants parallel coloring, both of which involve
moving integer data over the scatter context.
What other implementations are currently non-scalable? Do we need other
primitives, or would two-way integer operations over the MPIXAIJ scatter
and via an IS be sufficient?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/8c90c5a8/attachment.html>
